IMX8MM Adjust display brightness contrast saturation
619 次查看
OTan
We are using i.MX8MM android 9, kernel Linux4.14, we want to adjust display brightness contrast saturation for different LCD, could you share some information? thanks a lot
612 次查看
jimmychan
According to the release notes, the UI (brightness control) is not supported.
590 次查看
OTan
Do i.MX8MM support contrast adjust? It seems like no information about it on datasheet or RM.
