IMX8M NVCC_XXX power consumption calculations
karan_chauhan
Hi joanxie,
Can you please let me know, How to calculate the NVCC_XXX supply rails power consumption in IMX8MQ processor with example?
Thank & Regards,
Karan Chauhan
karan_chauhan
Hi joanxie‌,
I have gone through the application note but did not find how to calculate the IO supply voltage for different interface or NVCC_XXX supply rails current  consumption.
It would be good if you can provide the calculation or suggest solution which can help us.
Thanks!
Karan Chauhan
joanxie
for NVCC, you can refer to the data sheet,hope helpful for you
https://www.nxp.com/docs/en/data-sheet/IMX8MDQLQCEC.pdf
joanxie
for power consumption, pls refer to the power consumption application note as below:
https://www.nxp.com/docs/en/nxp/application-notes/AN12118.pdf
karan_chauhan
Hi Joan Xie,
Thanks!
Karan Chauhan
