IMX8M Mini PCI Change RC BAR Size
1,793 次查看
ay_tikit
Hello, We are trying to write data through PCI using a FPGA to IMX8M Mini. The IMX is the RC in this system. I am trying to change the BAR size on the IMX. Using the linux-imx 5.4.70, it seems that I cannot set a size to this bar, as anything I write to the BAR0 (0x10), the 1MB of size stays the same. Could you please give me a hint on how could I change this BAR, or where in the driver, size of this BAR is being set to 1MB.
1,773 次查看
ay_tikit
I got it figured out. I was able to increase BAR0 size on RC by adding a few lines to pcie-designware-host.c.
