IMX6Q ADDING PHP PACKAGES IN YOCTO(NEED HELP)
1,866 次查看
mustafabakircio
Hello guys ;
I have been working on the webserver application about 1 week , in my project I need to add php packages and php features to y image in yocto but I coundnt  make it  , I m finding  the php packages with
fsl-community-bsp/build :  bitbake -e php | grep "^PACKAGES="
 the result is
PACKAGE: php-cli php-dev php-apache2- ......  and etc .
When I put these packages to the local.conf like IMAGE_INSTALL_append = " php-cli php-fpm php-dev ..."
I get a build error   which is :
ERROR: php-staticdev not found in the base feeds (wandboard_quad cortexa9hf-vfp-neon-mx6qdl cortexa9hf-vfp-neon cortexa9hf-vfp armv7ahf-vfp-neon armv7ahf-vfp armv6hf-vfp armv5ehf-vfp armv5hf-vfp noarch any all).
acl-2.2.52-r0@cortexa9hf_vfp_neon acl-dbg-2.2.52-r0@cortexa9hf_vfp_neon acl-dev-2.2.52-r0@cortexa9hf_vfp_neon acl-doc-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-de-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-es-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-fr-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-gl-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-pl-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-sv-2.2.52-r0@cortexa9hf_vfp_neon acl-ptest-2.2.52-r0@cortexa9hf_vfp_neon alsa-conf-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-conf-base-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-dbg-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-dev-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-server-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-state-0.2.0-r5@wandboard_quad alsa-state-dbg-0.2.0-r5@wandboard_quad alsa-state-dev-0.2.0-r5@wandboard_quad alsa-states-0.2.0-r5@wandboard_quad alsa-utils-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aconnect-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsactl-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsaloop-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsamixer-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsaucm-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-amixer-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aplay-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aseqdump-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aseqnet-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-dbg-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-dev-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-doc-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-iecset-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-de-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-fr-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-ja-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-ru-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-midi-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-speakertest-1.0.28-r0@cortexa9hf_vfp_neon apache2-2.4.10-r0@cortexa9hf_vfp_neon apache2-dbg-2.4.10-r0@cortexa9hf_vfp_neon apache2-dev-2.4.10-r0@cortexa9hf_vfp_neon apache2-doc-2.4.10-r0@cortexa9hf_vfp_neon apache2-scripts-2.4.10-r0@cortexa9hf_vfp_neon apm-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-dbg-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-dev-3.2.2+14-r2@cortexa9hf_vfp_neon atftp-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-dbg-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-dev-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-doc-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftpd-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon attr-2.4.47-r0@cortexa9hf_vfp_neon attr-dbg-2.4.47-r0@cortexa9hf_vfp_neon attr-dev-2.4.47-r0@cortexa9hf_vfp_neon attr-doc-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-cs-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-de-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-es-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-fr-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-gl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-nl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-pl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-sv-2.4.47-r0@cortexa9hf_vfp_neon attr-ptest-2.4.47-r0@cortexa9hf_vfp_neon autoconf-2.69-r11@cortexa9hf_vfp_neon autoconf-dbg-2.69-r11@cortexa9hf_vfp_neon autoconf-dev-2.69-r11@cortexa9hf_vfp_neon autoconf-doc-2.69-r11@cortexa9hf_vfp_neon automake-1.14.1-r0@cortexa9hf_vfp_neon automake-dbg-1.14.1-r0@cortexa9hf_vfp_neon automake-dev-1.14.1-r0@cortexa9hf_vfp_neon automake-doc-1.14.1-r0@cortexa9hf_vfp_neon avahi-autoipd-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-daemon-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dbg-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dev-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dnsconfd-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-doc-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-bg-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ca-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-cs-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-da-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-de-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-el-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-au-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-ca-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-gb-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-nz-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-es-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fi-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fo-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fr-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-gl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-he-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-hu-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-id-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-it-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ja-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ms-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-nl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-pl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-pt-br-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ro-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ru-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sr-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sr+latin-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sv-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-uk-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-zh-cn-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-zh-tw-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-staticdev-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-utils-0.6.31-r11.1@cortexa9hf_vfp_neon base-files-3.0.14-r89@wandboard_quad base-files-dbg-3.0.14-r89@wandboard_quad base-files-dev-3.0.14-r89@wandboard_quad base-files-doc-3.0.14-r89@wandboard_quad base-passwd-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-dbg-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-dev-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-doc-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-update-3.5.29-r0@cortexa9hf_vfp_neon bash-4.3-r0@cortexa9hf_vfp_neon bash-dbg-4.3-r0@cortexa9hf_vfp_neon bash-dev-4.3-r0@cortexa9hf_vfp_neon bash-doc-4.3-r0@cortexa9hf_vfp_neon bash-ptest-4.3-r0@cortexa9hf_vfp_neon bc-1.06-r2@cortexa9hf_vfp_neon bc-dbg-1.06-r2@cortexa9hf_vfp_neon bc-dev-1.06-r2@cortexa9hf_vfp_neon bc-doc-1.06-r2@cortexa9hf_vfp_neon bcm4329-nvram-config-1.0-r0@wandboard_quad bcm4329-nvram-config-dbg-1.0-r0@wandboard_quad bcm4329-nvram-config-dev-1.0-r0@wandboard_quad bcm4330-nvram-config-1.0-r0@wandboard_quad bcm4330-nvram-config-dbg-1.0-r0@wandboard_quad bcm4330-nvram-config-dev-1.0-r0@wandboard_quad binutils-2.24-r0@cortexa9hf_vfp_neon binutils-dbg-2.24-r0@cortexa9hf_vfp_neon binutils-dev-2.24-r0@cortexa9hf_vfp_neon binutils-doc-2.24-r0@cortexa9hf_vfp_neon binutils-locale-bg-2.24-r0@cortexa9hf_vfp_neon binutils-locale-da-2.24-r0@cortexa9hf_vfp_neon binutils-locale-de-2.24-r0@cortexa9hf_vfp_neon binutils-locale-eo-2.24-r0@cortexa9hf_vfp_neon binutils-locale-es-2.24-r0@cortexa9hf_vfp_neon binutils-locale-fi-2.24-r0@cortexa9hf_vfp_neon binutils-locale-fr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ga-2.24-r0@cortexa9hf_vfp_neon binutils-locale-hr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-id-2.24-r0@cortexa9hf_vfp_neon binutils-locale-it-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ja-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ms-2.24-r0@cortexa9hf_vfp_neon binutils-locale-nl-2.24-r0@cortexa9hf_vfp_neon binutils-locale-pt-br-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ro-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ru-2.24-r0@cortexa9hf_vfp_neon binutils-locale-rw-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sk-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sv-2.24-r0@cortexa9hf_vfp_neon binutils-locale-tr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-uk-2.24-r0@cortexa9hf_vfp_neon binutils-locale-vi-2.24-r0@cortexa9hf_vfp_neon binutils-locale-zh-cn-2.24-r0@cortexa9hf_vfp_neon binutils-locale-zh-tw-2.24-r0@cortexa9hf_vfp_neon binutils-staticdev-2.24-r0@cortexa9hf_vfp_neon bison-2.7.1-r0@cortexa9hf_vfp_neon bison-dbg-2.7.1-r0@cortexa9hf_vfp_neon bison-dev-2.7.1-r0@cortexa9hf_vfp_neon bison-doc-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ast-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-da-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-de-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-el-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-eo-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-es-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-et-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-fi-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-fr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ga-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-gl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-hr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-hu-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-id-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-it-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ja-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ky-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-lt-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-lv-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ms-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-nb-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-nl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pt-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pt-br-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ro-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ru-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sq-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sv-2.7.1-........
I'm using dizzy branch and my kernel version is 3.10.17
I need to solve this issue but I ' m getting hopeless about it . Do you have any suggestion or do I missing something ?
I  stuck on this .
4 回复数
1,044 次查看
jimmychan
The error is " php-staticdev not found", so how about this ?
bitbake -e php | grep ^FILES_
1,044 次查看
mustafabakircio
Thank for your reply jimmychan
Yes I tried it and the result  is ;
FILES_php-doc="/usr/share/doc /usr/share/man /usr/share/info /usr/share/gtk-doc /usr/share/gnome/help /usr/lib/php5/php/doc"
FILES_php-cgi="/usr/bin/php-cgi"
FILES_php-locale="/usr/share/locale"
FILES=""
FILES_php-dbg="/usr/bin/.debug /usr/lib/apache2/modules/.debug /usr/lib/debug /usr/src/debug"
FILES_php-fpm-apache2="/etc/apache2/conf.d/php-fpm.conf"
FILES_php-fpm="/usr/sbin/php-fpm /etc/php-fpm.conf /usr/share/fpm /etc/init.d/php-fpm /lib/systemd/system/php-fpm.service /etc/php-fpm.d/www.conf.default"
Can you help me about how to use these informations about adding to my image?
1,044 次查看
jimmychan
3.10.17 is quite old. Have you try newer version BSP?
1,044 次查看
mustafabakircio
Hi jimmychan ;
And yes I  changed the branch and made it master branch , but I still taking the same error
I wonder if master branch not stable at all ?
Thanks ..
