IMX6 IPU - Video Capture
2,086件の閲覧回数
vinothkumarraje
All,
Need a clarification on IMX6 SOLO IPU programming. Our requirement is to capture video frames and dump it to the memory(CSI->SMFC->IDMAC).
To be more specific, an analog camera connected to a external decoder which connects to CSI1port as 8-bit interface. The video data format is BT656 720*480i YUV4:2:2 data.
The camera and decoder driver has been validated in different variant & works fine.
The current issue is to bring-up capture on IMX6 in QNX platform.  Referred the Linux BSP and programmed the CSI registers, still not able to see valid image on frame buffer and no status change in INT_STATUS(1 - 10) register.
Attaching the register dump taken on the target. Please review it.
Please point the debug key registers to check the state of IPU, like data get parsed on CSI register, DMA blocked in error, etc....
This table summarizes the pin details of external decoder connect to IMX6
Module LGA Pad
iMX6 Signal Name B1-Sample
Project Signal name
PAD Name
H25
IMX_CSI1_PIXCLK
DECODER_BT656_CLK
EIM_A16
G24
IMX_CSI1_DAT(12)
DECODER_BT656_D(0)
EIM_A17
J22
IMX_CSI1_DAT(13)
DECODER_BT656_D(1)
EIM_A18
G25
IMX_CSI1_DAT(14)
DECODER_BT656_D(2)
EIM_A19
H22
IMX_CSI1_DAT(15)
DECODER_BT656_D(3)
EIM_A20
H23
IMX_CSI1_DAT(16)
DECODER_BT656_D(4)
EIM_A21
F24
IMX_CSI1_DAT(17)
DECODER_BT656_D(5)
EIM_A22
J21
IMX_CSI1_DAT(18)
DECODER_BT656_D(6)
EIM_A23
F25
IMX_CSI1_DAT(19)
DECODER_BT656_D(7)
EIM_A24
PAD Mux register programming sequence
HW_WR_REG32(ctrl_vaddr+EIMADDR16_MUXCTRL_OFFSET, 0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR16_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_PIXCLK*/
HW_WR_REG32(ctrl_vaddr+EIMADDR17_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR17_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(12)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR18_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR18_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(13)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR19_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR19_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(14)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR20_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR20_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(15)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR21_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR21_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(16)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR22_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR22_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(17)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR23_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR23_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(18)*/
HW_WR_REG32(ctrl_vaddr+EIMADDR24_MUXCTRL_OFFSET,0x00000002);
HW_WR_REG32(ctrl_vaddr+EIMADDR24_PADCTRL_OFFSET,0x0000B0B1);/*IMX_CSI1_DAT(19)*/
Vinoth
Original Attachment has been moved to: imx_ipu_reg_dump_2.txt.zip
ラベル(3)
タグ(1)
3 返答(返信)
776件の閲覧回数
igorpadykov
Hi Vinothkumar
CSI BT656 OSless example can be found in SDK, with
description in sect.18.5.2.3 BT656 mode iMX6_Firmware_Guide.pdf
i.MX 6Series Platform SDK  : Bare-metal SDK for the i.MX 6
in linux one can dump IPU/CCM registers and compare them with custom
board.
776件の閲覧回数
vinothkumarraje
Hi Igor,
I had referred the IMX SDK firmware guide, its much useful on pointing the key registers.
Need a clarification on programming the CSI IPU_CSI1_SENS_FRM_SIZE & IPU_CSI1_ACT_FRM_SIZE register.
In our custom board, SD NTSC camera connect to the decoder and decoder programmed to send BT656, YUV4:2:2, NTSC interlaced, 720*243 fileds.
So what should be the values of SENS_FRM_SIZE & ACT_FRM_SIZE
1)
CSI1_SENS_FRM_WIDTH = (720-1);
CSI1_SENS_FRM_HEIGHT = (243-1);
CSI1_ACT_FRM_WIDTH = (720-1);
CSI1_ACT_FRM_HEIGHT = (240-1);
or
2)
CSI1_SENS_FRM_HEIGHT = (525-1);
CSI1_ACT_FRM_HEIGHT = (480-1);
Vinoth
776件の閲覧回数
igorpadykov
Hi Vinoth
size settings for interlaced case are the same as for non-interlaced.
~igor
