How to use encoder_test.out on i.MX6
843 次查看
dongsulee
I think it's a basic question. When I executed /unit-test/JPEG/encoder_test.out follow usage, I got a error.
Could you please explain what I have a wrong?
1. The way that I executed it and there isn't a command for IOCTL.
root@var-som-mx6:/unit_tests/JPEG# ./encoder_test.out -d /dev/mxc_vpu -f outfile.rgb
mxc_vpu 2040000.vpu_fsl: No such IOCTL, cmd is -2140645888
FILE SIZE 786432
VIDIOC_QUERYCAP: Invalid argument
标签 (2)
800 次查看
dongsulee
Hi igor,
I'm sorry late.
It is working well. Could I ask you one more?? Is other unit-test program available??
I think JPEG on unit-test isn't available, and there are many unit-test. I'm a little confused which it is available.
You replied the best answer for me.:) Thank you so much!!
800 次查看
igorpadykov
Hi Dong
one can look at mxc_vpu_test documentation:
doc\mxc_vpu_test\test - imx-test - i.MX Driver Test Application Software
800 次查看
igorpadykov
Hi Dong
one can try ./mxc_vpu_test.out -E "-i Test_25fps_qcif.yuv -w 240 -h 320 -f 7 -o file.jpg".
Also for var-som-mx6 board one can look on
VAR-SOM-MX6 GSTREAM - Variscite Wiki
VAR-SOM-MX6 GSTREAM FSLC - Variscite Wiki
