How to set DNS server details in Sabresd board using Freescale Ethernet App?
931 次查看
teddy123
Recently, I came across this problem. I tried to connect Ethernet to my sabresd board and succeeded by connecting it to Internet by setting the IP address, Gateway and DNS details from the android shell. But I am not able to use the Freescale Ethernet app which came along with the Android Souce package to set the above mentioned details. Have any tried using this Ethernet app?
标签 (4)
标记 (1)
723 次查看
SergioSolis
Hello, I just tried it and didn't have any problems setting the proxy, port and bypass.  Did you try those settings?, or only static ip/dns ?... I haven't tried those yet
