How to operate i.MX28 TIMROT timer in duty cycle mode?
878 次查看
sidebranch
I would like to use the TIMROT v2 module TIMER3 in duty cycle measurement mode.
As a first test, I just want to measure the duty cycle of the 32 kHz crystal clock.
As the clock tick input, I select TICK_ALWAYS (0xF)
As the test input, I select the 32 kHz crystal clock (0xB)
root@imx28evk:~# devmem2 0x800680e0 w 0x000b02cf
However, the DUTY_VALID does not go high as I would expect (i.e. the test signal is an approx. 50/50 duty cycle signal).
IRQ goes high, and LOW_RUNNING_COUNT gets a value, but HIGH_RUNNING_COUNT does not.
Read at address  0x800680E0: 0x000B82CF
Read at address  0x800680F0: 0xF1F83AD9
Read at address  0x80068100: 0x00000000
- It is not documented how UPDATE and RELOAD bits must be set in duty cycle mode.
- It is not documented how IRQ is handled in duty cycle mode
- Must I preload the FIXED_COUNT register to 0xffffffff?
Thanks for any insights to get this working,
Leon.
640 次查看
alejandrolozan1
Please refer to the attached files. The code is using the TIMROT module but as an encoder.
I hope it helps.
Alejandro
639 次查看
jamesbone
alejandrolozano
Can you please share your example ?
