I want to know how to keep UBoot logo on imx8mp until android animation.
The BSP version uses Android 11.0.0_2.6.0.
who can help?
I have the same question,do you resolve it?
Thanks.
Hi @Rayn_Jang,
I hope you are doing well.
To keep the u-boot logo from u-boot to kernel one can refer to the below-mentioned document.
Please provide more information regarding the display for further support.
Thanks & Regards,
Dhruvit Vasavada
Hi, Dhruvit
I have already checked the link information you provided above.
The information you provided cannot be applied as BSP information for imx6.
I am using BSP for imx8mp.
Display information uses mipi-dsi interface and uses rm67295 panel.
Currently, the logo is displayed normally in Uboot.
Hi @Rayn_Jang,
Implementation will be similar to the given post.
Please refer to the below-mentioned thread, where a similar implementation is done on i.MX8MN.
Please try referring to the patches mentioned in the above link.
Thanks & Regards,
Dhruvit Vasavada
Hi, Dhruvit
thank you for your answer.
I applied the patch previously by referencing the link mentioned above.
However, the symptoms are the same.
Please help me.
Hi @Rayn_Jang,
Please share the patch that you applied.
The above patch is for i.mx8mn and a different kernel version, you might need to change it for i.mx8mp.
Thanks & regards,
Dhruvit Vasavada
Hi @Rayn_Jang,
Did you apply the third patch u-boot_0002.patch provided in previous link?
sec_mipi_dsim.c is moved to /drivers/video/nxp/imx in the latest u-boot-imx
Thanks & Regards,
Dhruvit Vasavada
Hi, Dhruvit
I also applied the u-boot_0002.patch file, but it didn't work so I deleted it.
Hi @Rayn_Jang,
Could you please share debug logs for further debugging?
Thanks & Regards,
Dhruvit Vasavada
It hasn't been resolved yet.
