How to increase ASRC channel with cs42888 codec on sabre-AI ?
868件の閲覧回数
jackeyko
Hi NXP,
I would like to increase ASRC channel of CS42888 codec on Sabre-AI board?
Currently, only stereo(input, ouput -2 chanels) are applied on HIFI-ASRC-FE .
[sound device]
card 0: cs42888audio [cs42888-audio], device 0: HiFi cs42888-0 []
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: cs42888audio [cs42888-audio], device 1: HiFi-ASRC-FE (*) []
  Subdevices: 1/1
The ASRC of I.MX6  support up to 10 channel in i.MX_Linux_Reference_Manual.pdf  as below.
29.2 Introduction
The Asynchronous Sample Rate Converter (ASRC) converts the sampling rate of a signal
to a signal of different sampling rate. The ASRC supports concurrent sample rate
conversion of up to 10 channels. The sample rate conversion of each channel is
associated to a pair of incoming and outgoing sampling rates. The ASRC supports up to
three sampling rate pairs simultaneously.
Jackey
ラベル(3)
701件の閲覧回数
art
Generally, please follow the Section 7.2 of the attached document.
Artur
