How to enable temperature monitoring in IMX7D?
3,618件の閲覧回数
javerv
I just want to check how to enable temp monitoring in imx7d?
I have a custom im7d board and I cant seem to find where to enable temp monitoring in /sys/class/thermal
In my menuconfig, I can confirm that below is enabled.
Device Drivers > Generic Thermal sysfs driver >Temperature sensor driver for i.MX SoCs
However, after loading the kernel no thermal zone was loaded in sysfs.
root@myboard:~# ls /sys/class/thermal/
root@myboard:~#
I'm expecting something like below  (based from my imx7dsabresd board)
root@imx7dsabresd:~# ls /sys/class/thermal/
cooling_device0/ cooling_device1/ thermal_zone0/
BTW, I'm using Yocto Zeus.
Javer
14 返答(返信)
820件の閲覧回数
henneond
I had a similar problem. For me, the issue was that the cpufreq driver was not working and that caused imx_thermal driver probe to fail. Cpufreq driver probe was failing because of a missing cpu-supply property on CPU DT node. This property needs to reference a regulator which supplies the CPU. I am using the TechNexion pico-pi board and a pmic was already defined in imx7d-pico.dtsi like this:
&i2c4 {
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_i2c4>;
	status = "okay";
	pmic: pfuze3000@8 {
		compatible = "fsl,pfuze3000";
		reg = <0x08>;
		regulators {
			sw1a_reg: sw1a {
				regulator-min-microvolt = <700000>;
				regulator-max-microvolt = <3300000>;
				regulator-boot-on;
				regulator-always-on;
				regulator-ramp-delay = <6250>;
			/* use sw1c_reg to align with pfuze100/pfuze200 */
			sw1c_reg: sw1b {
				regulator-max-microvolt = <1475000>;
				regulator-boot-on;
			sw2_reg: sw2 {
				regulator-min-microvolt = <1800000>;
				regulator-max-microvolt = <1850000>;
				regulator-boot-on;
			sw3a_reg: sw3 {
				regulator-min-microvolt = <900000>;
				regulator-max-microvolt = <1650000>;
				regulator-boot-on;
			swbst_reg: swbst {
				regulator-min-microvolt = <5000000>;
				regulator-max-microvolt = <5150000>;
			snvs_reg: vsnvs {
				regulator-min-microvolt = <1000000>;
				regulator-max-microvolt = <3000000>;
				regulator-boot-on;
			vref_reg: vrefddr {
				regulator-boot-on;
			vgen1_reg: vldo1 {
			vgen2_reg: vldo2 {
				regulator-min-microvolt = <800000>;
				regulator-max-microvolt = <1550000>;
			vgen3_reg: vccsd {
				regulator-min-microvolt = <2850000>;
			vgen4_reg: v33 {
			vgen5_reg: vldo3 {
			vgen6_reg: vldo4 {
So I did this in my dts:
&cpu0 {
	cpu-supply = <&sw1a_reg>;
&cpu1 {
 And both the CPU frequency scaling and temperature monitoring started working.
2,512件の閲覧回数
HelbertPaulino
I'm new here and using Yocto project to make custom Linux. I did the recommended procedures described in Toradex User Manual, but I'm not having success.
Have somebody some explanation about this temperature sensor issue?
Thanks very much and have a great 2022!
2,482件の閲覧回数
Florens
For us activating "CONFIG_ARM_IMX_CPUFREQ_DT=y" helped.
2,504件の閲覧回数
javerv
Hello Helbert,
Could you advise what u-boot and kernel version are you using?
BTW, can you check if you can detect the temperature in u-boot?
Javer
3,516件の閲覧回数
igorpadykov
Hi Javer
one can try settings described in sect.2.9.4 Menu Configuration Options
i.MX Linux Reference Manual
3,516件の閲覧回数
javerv
Hello Igor,
Good day!
Yes, I already implemented that as I have explained above.
I'm thinking if there is any pin that can affect this?
Or is there any modification in device-tree I need to implement?
Javer
3,516件の閲覧回数
igorpadykov
Hi Javer
what bsp used in the case, suggest to try nxp releases from
source.codeaurora.org/external/imx/linux-imx  repository
linux-imx - i.MX Linux kernel
3,516件の閲覧回数
javerv
Hello Igor,
Additional information:
I put my software build in an SD card and put in imx7dsabre board.
There I can find below.
root@myboard:~#
But everytime I put the SD card in our custom board.
I cant find anything insie thermal folder
root@myboard:~#
The difference between my board and sabresd board is the PMIC.
Is that affects the driver for thermal?
Javer
3,515件の閲覧回数
igorpadykov
Hi Javer
I think yes as all these drivers :  thermal, pmic, pmic regulator, cpu frequency scaling
(CPUFREQ) are tightly coupled with each other. So it is necessary to port new
pmic using sect.2.5 Power Management  i.MX Linux Reference Manual
i.MX Porting Guide
3,516件の閲覧回数
javerv
Hello Igor,
Below is what I'm currently using.
https://source.codeaurora.org/external/imx/imx-manifest  -b imx-linux-zeus -m imx-5.4.3-2.0.0.xml
Javer
3,324件の閲覧回数
michael_pavlovi
Did you ever resolve this issue?  I'm experiencing the same problem where it appears the driver code is not starting even though it is configured properly in the Linux Menu Config.
Thanks very much!
Michael
3,151件の閲覧回数
javerv
Hello Michael,
This issue is still not resolved on our end.
Javer
3,299件の閲覧回数
Florens
Same Problem on linux-mainline 5.4. cpufreq_driver is not set resulting in no thermal_zone in sysfs. In 4.19 it works. Any Ideas?
3,150件の閲覧回数
javerv
Hello Florens,
Javer
