I modify status in imx8x-mek.dtsi, imx-ss-dma.dtsi, imx8qxp-mek-rpmsg.dts to "okay".
&flexcan1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_flexcan1>;
xceiver-supply = <®_can_stby>;
status = "okay";
But, the status is still "disabled" when I run kernel...
root@imx8qxpc0mek:/sys/firmware/devicetree/base/bus@5a000000/can@5a8d0000# cat status
disabled
root@imx8qxpc0mek:/sys/firmware/devicetree/base/bus@5a000000/can@5a8f0000# cat status
disabled
I wonder which .dts file control the status of CAN on MCIMX8QXP-CPU board. And, how to modify .dts file to register can0 on /dev?
Thank you!
Solved! Go to Solution.
Hi Ale2
for enabling can one can refer to below link, section "Modifying default configuration" :
Hi Ale2
