I am trying to bring our old build of an iMX28 that was using Yocto dizzy on Ubuntu 14.04 to rocko on Ubuntu 16.04.
I have started with:
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b rocko
change the default local.conf to have:
MACHINE ??= 'imx28evk'
DISTRO ?= 'fslc-framebuffer'
and successfully built the 'core-image-minimal' with files in tmp/deploy/images/imx28evk/...
I am now trying to burn this onto an sd card to test. Under the new system, the default output is now 'wic.gz' not 'sdcard' and I'm trying to use the command:
wic create .../sources/meta-freescale/wic/imx-uboot-mxs-bootpart.wks -e core-image-minimal
It creates a file called "<name>.direct", but when burn onto a card it only has two partitions. From the .wks file I would expect 3 partitions. I would also expect one of them of type 53 (or 'S') to hold the bootstream. The .wks file cannot have a partition type of 53 it is restricted to only a few know file system types.
Q. As the iMX28 ROM code is looking for a DOS partition of type 53 for it's boot stream, what do I need to do to get wic (or some other tool) to create the proper SD card?
Under the old dizzy the final output called "<name>.sdcard" had everything required and could be 'dd'ed directly onto a card.
Colin Moloney
Hi Marco,
I was able to get the 'morty' version of YOCTO to build an image for the imx_evk28 that booted correctly.
The changes, discussed above with Otavio, look like they will work on 'rocko' version of YOCTO. I've tried the changes as a quick hack of my workspace and they produced a bootable uSD. I haven't got any further because higher priority work has interrupted me.
I am currently trying to get our product to build for 'morty' (using imx-bootlets, not u-boot). It is booting but I'm still getting all the init scripts in place for our hardware and applications. So I'm very close to succeeding there. After that I'll port it to 'rocko' and hopefully u-boot too.
Colin
can't boot image for imx8qm created out of sumo
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.78-1.0.0_ga.xml
MACHINE=imx8qmmek DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b bld-xwayland
Hello Colin Moloney,
There wic.gz format was introduced on the latest branches and it’s a compressed format similar to the sdcard format. I’m investigating if you can add the sdcard format so you get an .sdcard file as output as well.
In the meantime, you should be able to extract and write on an SD card with something like:
$ gunzip -c <IMAGE>.wic.gz | sudo dd of=/dev/sdX bs=1M iflag=fullblock oflag=direct conv=fsync
I hope this helps!
Thanks gusarambula,
but the problem is not writing the image to the card, it is that the image only contains two partitions and that the boot partition is not of type 53 that the iMX28 needs.
- CM
I have since followed https://www.nxp.com/docs/en/application-note/AN12024.pdf and used YOCTO 'morty'. This produces a .sdcard output that has three partitions and with the boot partition of type 53. The evk only partly boots: u-boot runs and load the kernel but the kernel waits forever for mmcblk0p3 to become ready. The card is OK because I can mount it on a PC and observed the 'p3' partition. Interestingly there is no /lib/modules directory in the root file system; has the structure of linux changed or has the build not built everything?
-CM
So I did check what was missing.
Please apply following two patches to OE-Core / Poky:
[1/2] parted: add ontrack DM6 aux3 support - Patchwork
[2/2] wic: add ontrack DM6 aux3 support - Patchwork
and these two in meta-freescale:
[1/2] u-boot-fslc-mxsboot: Add dtc as build dependency - Patchwork
[2/2] wic: Fix image generation for i.MX MXS SoC family - Patchwork
Let me know if it works for you.
Thanks Otavio,
I applied the patches and began a clean build. The image is almost
correct:
There are 3 partitions and the FAT32 and the EXT4 look OK but the boot
stream on partition 1 of type 0x53 has the wrong offset in the header.
The file
"core-image-minimal-imx28evk-20180427075602.rootfs.uboot-mxsboot-sdcard"
starts:
00000000 33 22 11 00 01 00 00 00 01 00 00 00 01 00 00 00
3".............. |
00000010 00 00 00 00 00 00 00 00 01 00 00 00 04 08 00 00
00000020 28 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000800 97 73 ba 38 41 db b9 70 a6 15 cb b4 9a 1b 1f 4d
.s.8A..p.......M |
00000810 f8 40 89 5e 53 54 4d 50 01 01 01 00 9b a4 00 00
.@.^STMP........ |
00000820 09 00 00 00 00 00 00 00 01 00 07 00 06 00 01 00
00000830 01 00 00 00 73 67 74 6c 40 ad e3 a1 32 0d 02 00
....sgtl@...2... |
and so would only be correct if burnt to address 0x00100000 (sector
0x0800) but it is burnt to address 0x00000400 and so the offset in the
header should be 0x000000006.
I tried adding '-p 2' to the line in
meta-freescale/classes/image_types_fsl.bbclass (just as a test):
IMAGE_CMD_uboot-mxsboot-sdcard = "mxsboot -p 2 sd
$/u-boot-$.$ \ $/$.rootfs.uboot-mxsboot-sdcard"
and the file
"core-image-minimal-imx28evk-.......rootfs.uboot-mxsboot-sdcard"
is now:
3".............. |
00000010 00 00 00 00 00 00 00 00 01 00 00 00 06 00 00 00
.s.8A..p.......M |
.@.^STMP........ |
....sgtl@...2... |
and the .wic looks OK too. I couldn't make the 'wic' command
work so I just unzipped the .wic.gz and used 'dd' to burn the image.
[ The command "wic write sync
didn't know what 'wic' was.]
It now load u-boot which then loads Linux and boots and mounts
/dev/mmcblk0p3 as root.
So, obviously I shouldn't put a hard coded '-p 2' in the
IMAGE_CMD_uboot-mxsboot-sdcard.
How should the location of the bootstream be handled?
The .wks.in template is translated into
part u-boot --source rawcopy
--sourceparams="file==core-image-minimal-imx28evk-20180430014159.rootfs.uboot-mxsboot-sdcard"
--ondisk mmcblk --fstype=ontrackdm6aux3 --align 1
part /boot --source bootimg-partition --ondisk mmcblk
--fstype=vfat --label boot --active --align 4096 --size 16
part / --source rootfs --ondisk mmcblk --fstype=ext4
--label root --align 4096
bootloader --ptable msdos
and the offset of the bootstream is already embedded in
"core-image-minimal-imx28evk-20180430014159.rootfs.uboot-mxsboot-sdcard".
Either:
1. 1. the position of the bootstream needs to be extracted
from the .wks when building the rootfs.uboot-mxsboot-sdcard
2. 2. the definitions/placements in the .wks need to be dynamic
and move partitions around depending on how
rootfs.uboot-mxsboot-sdcard was built
1. 3. the offset in the header of the
bootstream needs to be adjusted at the time
the .wic is written to the sdcard.
4. something I haven't thought of...
Colin Moloney
Hello, thanks for the test.
Please apply those changes (http://termbin.com/qzxh ) and see if this works for you.
If it does, I send a new patch version for merge.
Hi, sorry about the delay I've been on a different project for a few weeks.
1) I'm trying to test your fix but even after 'rm -rf tmp' I can't get the bitbake to complete the do_image_wic step. I complains that the .wks file doesn't exist. The .wks.in exists. What step creates the .wks from the .wks.in? I can't get it to re-perform that step.
2) The change in http://termbin.com/qzxh is to set the 'align' to 1MiB so that it matches the internal default inside mxsboot, of 2048 blocks [Which only works if the boot partition comes first in the list of partitions.]
Wouldn't it be more controlled to set the origin a little more explicitly so it is visible reading the scripts without needing to know the source code for mxsboot? eg. (still only works if the boot is the first partition, but is explicit)
a) In build/conf/local.conf
# Set origin to 1MiB and the -p arg to mxsboot to match (in blocks/sectors)
MXSBOOT_SD_BOOTORIGIN = "1"
MXSBOOT_SD_ARGS = "-p $(expr 2 '*' ${MXSBOOT_SD_BOOTORIGIN})"
b) In sources/meta-freescale/wic/imx-uboot-mxs-bootpart.wks.in
part u-boot --source rawcopy --sourceparams="file=${IMAGE_NAME}.rootfs.uboot-mxsboot-sdcard" --ondisk mmcblk --fstype=ontrackdm6aux3 --align ${MXSBOOT_SD_BOOTORIGIN}
c) In sources/meta-freescale/classes/image_types_fsl.bbclass
IMAGE_CMD_uboot-mxsboot-sdcard = "mxsboot ${MXSBOOT_SD_ARGS} sd ${DEPLOY_DIR_IMAGE}/u-boot-${MACHINE}.${UBOOT_SUFFIX} ${DEPLOY_DIR_IMAGE}/${IMAGE_NAME}.rootfs.uboot-mxsboot-sdcard"
BTW, does the OE .wic system have a way of specifying the origin of the partitions explicitly? A bit like a linker might place objects in memory, working around explicit origins and sizes?
Colin Moloney
OtavioSalvador, would you know if this is a known issue with the image generated on the rocko branch?
