How to configure vpu enc when recording video on imx8qm
4,700件の閲覧回数
jack-cap
Hardware platform: imx8qm
software platform: imx-p9.0.0_2.1.1-auto-ga-android
I wrote an application for recording 4-way videos, the application using Camera 1.0 Api. When the recording application is started, It using software coding rather then vpu enc,The cpu is high occupancy as shown in the figure. and adb logcat in the appendix.
Has anyone had this problem?  please give me a solution, Thanks!
12 返答(返信)
4,192件の閲覧回数
joanxie
how many camera do you use? I haven't tested mediarecorder, but for gstreamer, which can support multi-channel encoding
4,193件の閲覧回数
jack-cap
any progress ,pls notify me. thanks.
4,193件の閲覧回数
jack-cap
i.MX ProcessorsProcessor Expert Software@‌joanxie
about android record multiple videos, any plans to solve skip frame?
4,193件の閲覧回数
chenguoyin
can you try to use android-10 GA version? In pi version, we may limited the vpu instance to be used as 1
4,193件の閲覧回数
jack-cap
chenguoyin i.MX ProcessorsProcessor Expert Software
when recording four videos, I found four vpu_instance on  top command result. so in android p version, the number of vpu instance is four.
4,193件の閲覧回数
jack-cap
chenguoyin
when record four videos , I find four vpu_instance on top command result.
4,193件の閲覧回数
jack-cap
Any progress ?
4,193件の閲覧回数
jack-cap
@joanxie
The board has 4 cameras on imx8 about android OS. Recording one camera video is normal when use mediarecorder. but recording multiple (>2) channel camera video has skip frame. when mediarecorder is working ,the vpu_instance process will be found on top command. The number of vpu_instance is the same as the mediarecorder channel video number.
And how to use gstreamer on Android OS ?
4,193件の閲覧回数
jack-cap
4,193件の閲覧回数
joanxie
maybe you can refer to the surroundview solution from official website, you can find application note and source code there:
https://www.nxp.com/design/designs/i-mx-surround-view-system:SURROUND-VIEW-APPLICATION
4,193件の閲覧回数
jack-cap
@Joan Xie
Are there other test cases for recording multiple videos on android ?
4,193件の閲覧回数
jack-cap
I want to record four channels of video with android api (mediarecorder), but the recorded video has skip frame, please help to analysis.
