I want to compile ffmpeg for my arm machine. I download ffmpeg file. After that i tried to compile with cross compiling but i couldn't compile. I have a error like this:
arm-poky-linux-gnueabi-g++ is unable to create an executable file.
C compiler test failed.
What should i do?
Can you tell me how can i compile ffmpeg step by step?
Thank you.
Best Regards.
Alper KAĞITCI
Hello Alper KAĞITCI,
Are you able to compile a simple .c file as a test?
I would recommend looking at the following training which follows a kernel compile step by step. However, in your case it seems that the problem may be with the flags when compiling ffmpeg.
https://community.freescale.com/docs/DOC-95225
Please also share the full command you are using, I suspect that the cross compiling may not be configured correctly.
Dear Gusarambula,
Cross compiler is : arm-poky-linux-gnueabi-g++
Infact I generated SDK out of the Yocto project :fsl-imx-x11/
I want to create openCv wıth ffpmpeg support .
I can run my helloworld and even ı can use ımage fıles and dısplay them ın the sabre board usıng opencv
code , whıch ı compıled usıng my cross compıler on my host machıne .
My Problem ıs ı wanna have a ffmpeg support for OPENCV lıbrary , seems by default fsl-ımx-x11 ımage doesnt create opencv wıth ffmnpeg support .
Kındlly help here.
Wıth regard and respect,
Alper Bey
Hello Alper Bey,
You may even add ffmnpeg using Yocto. Please look at the document below:
