How to adjust Contrast in IPU DP module for i.MX6Quad
619 次查看
yuuki
Senior Contributor II
Dear all,
We refer to the following document.
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-CON-F0223.pdf
 - p24 IPUv3 Color Space Conversion
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-CON-F0119.pdf
 - p49 DP (Display Processor)
We understand that we can coordinate Contrast by IPU DP module.
How to achieve  contrast adjustment under condition RGBA input and RGBA output using IPU DP module ?
Please provide sample code and  document of the code.
Yuuki
标签 (2)
标记 (2)
459 次查看
b36401
It can be performed with IPU Image Converter color conversion:
Y’=Y*k + b
Cb’= (Cb-128)*k+128 = k*cb+128(1-k)
Cr’= (Cr-128)*k+128 = k*Cr+128(1-k)
here "k" is contrast factor and "b" is brightness level.
Victor
459 次查看
yuuki
b36401
Dear Victor-san,
Thank you for your response.
Would you tell me a procedure and the method to perform it in Image Converter?
Is there the sample code?
Is there the method to perform this in IPU Display Processor?
Yuuki
