How do i interface ov5640 with imx6qdl board?
483 次查看
shrinidhirao
Hi, I am using i.mx6qdl board with Yocto running on it. I have connected ov5640 camera at the cmos connector socket according to the software manual. When i run imx.camera application on yocto it gives an error, engine reset failed. How do i fix this issue? My terminal on the laptop(connected to the board through USB and running minicom) Gives and Error: Slave not found.
How do i fix this?
397 次查看
jimmychan
what BSP are you using?
please check the I2C communication between camera and board is working.(e.g. pin mux setting, I2C address )
