Hi Community!
We have using IMX8MM and yocto Linux 4.19.
I want to add the "Read Only", "Sync" and "UTF-8" option when automounting a USB / SD card.
(ex : $ mount -o ro,sync,utf8 ~~ ~~)
Is there any good solution?
I modified the line
MOUNT="$MOUNT -o umask=007,gid=`awk -F':' '/^disk/{print $3}' /etc/group`"
in "automount" function in "/etc/udev/scripts/mount.sh".But it didn't work.
Takashi Kashiwagi
Solved! Go to Solution.
Hi Takashi
this is general linux question and may be recommended to post it on kernel mail list :
http://vger.kernel.org/vger-lists.html
Hi Takashi
Hi igor-san
thank you for your reply.
First, I will check the kernel mail list.
Takashi Kashiwagi
Hi Community.
I forgot to write the solution, so I will write it.
The files to be modified are the following files.
"sources / poky / meta / recipes-core / udev / udev-extraconf / mount.sh"
I added the "ro, utf8, sync" option to the "mount" command in the above file.
T.Kashiwagi
