HAB failsafe mode imx8mm
antonio_santagi
I read on the HAB API documentation that there is a failsafe mode API call from u-boot, on imx8m mini.
3.12 Failsafe mode
void(* hab_rvt::failsafe)(void)
Enter failsafe mode.
This is supposed to use an entry in a ROM table, however they don't say if the ROM table has default values and what those functions do and how to add the ROM table to u-boot.
Are there other documents or examples showing how to use this failsafe mode in practice ?
thank you
Tags (3)
Yuri
@antonio_santagi
  Use "HABv4 RVT Guidelines and Recommendations"
https://www.nxp.com/docs/en/application-note/AN12263.pdf
Yuri.
