I have one build here that refuses to include this library. Been through a couple of threads here, and everything looks correct (followed the multi-media guide and have the tarballs in /var/tmp/pkgs, building for an mx6q, turned on the plugins and gstreamer). Can I get some pointers on how to track down why this won't give a rootfs/usr/lib/gstreamer/libmfw_vpu.so?
can you try installing the specific package? Something like this:
ltib $ for mode in prep scbuild scdeploy; do ./ltib -m $mode -p gst-fsl-plugins; done
that should install the library on the path you mentioned.
That build it. Any idea why I have to do this by hand (or remove .lock_file before it would work)? Don't know much of the inner workings of ltib (yet?).
I do not know why sometimes the deployment for some packages is not done properly. Nice that it worked.
Leo
