GPS on IMX6SL ICS
GPS on IMX6SL ICS
2,951 次查看
raghavendraning
I am using uart interface for GPS in my imx6sl.cat /dev/ttymxc works fine .From my any of the android gps-apps i could't able to receive data.
But in my logcat i could able to get NMEA data from my HAL lib gps.default.so
I am using
HAL-->gps.default.so(which i compiled by gps_serial.c)
In BoardConfig.mk--->
BOARD_HAVE_HARDWARE_GPS := true
USE_NMEA_GPS_HARDWARE := true
Can any one help me to fix this issue.
标签 (3)
标记 (3)
3 回复数
2,372 次查看
raghavendraning
Hi Arulpandiyan,
Yeah.It has been solved.I used some other gps libraries.
2,372 次查看
eric_kang
Dear raghavendra ningoji,
I have the same problem in i.MX7D/Android M6.0.1.
Could you share the detailed method?
I'll send the message with my e-mail address to you.
2,372 次查看
balashanmugam
hi raghav,
     Have you solved this issue, If you solved can you pls share the details, we are also facing the same kind of issue in our module.
Arulpandiyan V
