By default, the maximum FreeRTOS tick rate is 1 kHz (1 ms). But you can go to a higher frequency. For this you have to provide your own version of the pdMS_TO_TICKS() macro in FreeRTOSconfig.h
I hope this helps,
Erich
So if I want that the scheduler re-evaluate every 100us I have simply to add:
#define configTICK_RATE_HZ 10000
#define pdMS_TO_TICK ( timeInUs ) ( timeInUs * configTICK_RATE_HZ /1000000 )
right? in this case ms_to_tick is actually us_to_tick
Older FreeRTOS ports used something like this:
vTaskDelay(50/portTICK_RATE_MS);
Which is a problem if the tick rate >1 kHz.
That's why newer FreeRTOS ports (I think from 9.0.0 on) use the pdMS_TO_TICKS() macro:
vTaskDelay(pdMS_TO_TICKS(50));
which is defined as
/* Converts a time in milliseconds to a time in ticks. This macro can be
overridden by a macro of the same name defined in FreeRTOSConfig.h in case the
definition here is not suitable for your application. */
#ifndef pdMS_TO_TICKS
#define pdMS_TO_TICKS( xTimeInMs ) ( ( TickType_t ) ( ( ( TickType_t ) ( xTimeInMs ) * ( TickType_t ) configTICK_RATE_HZ ) / ( TickType_t ) 1000 ) )
#endif
in projdefs.h
So as long as you are using pdMS_TO_TICKS and not portTICK_RATE_MS you are fine.
I hope this helps,
Erich
