Find USBPHY_CTRL Resistor in kernel tree ?
1,029件の閲覧回数
jaymind
I have custom board with i.MX6Q used and in which UTMI PHY2 used for USB connection to FTDI FT2232H IC.
So for setting and configuration I want to verify below registers,
USBPHY_CTRL
and want to check these 2 bits ENUTMILEVEL3 and ENUTMILEVEL2, whether it set or not.
So please suggest me that where can I find these USBPHY_CRTL reg. in which file or in which directory in kernel tree. ?
I search it in drivers->usb->core->driver.c, arch->arm->mach-max6->usb_h2.c but I didn't find any significance or clue related to that register.
Any one can suggest me about this.
Thanks in advance
Jaymin D
ラベル(2)
タグ(2)
810件の閲覧回数
jaymind
Dear Igorpadykov,
Thanks for help,
Its helpful me lot.
Finally I founded these 2 bits in file name as "reg-usbphy-mx6.h" in
/arch/arm/plat-mxc/include/mach/
and their usage founded in file "usb_h1.c" in
/arch/arm/mach-mx6/
I founded that they are set. :smileyhappy:
Bit no. 14 for UTMI level 3(0x8000) and bit no. 15 for UTMI level 2(0x4000)
Thank you for your share.
Jaymin D
4 返答(返信)
810件の閲覧回数
igorpadykov
Hi Jaymin
these bits may be set automatically by driver and used for
low speed devices, FT2232H does not support low speed.
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT2232H.pdf
810件の閲覧回数
jaymind
Dear Igorpadykov,
Thanks for reply, it will help me.
But can you please specify me that which driver set these bits ?
I mean which driver USB driver of i.MX6Q or FTDI FT2232H usb driver. ? :smileyconfused:
If you explain related to this topic in little more then it will surely benefit me.
Jaymin D
810件の閲覧回数
igorpadykov
Hi Jaymin
please look at attached document
Chapter 41 CHIPIDEA USB Driver
it describes i.MX6 linux usb driver.
811件の閲覧回数
jaymind
Dear Igorpadykov,
Thanks for help,
Its helpful me lot.
/arch/arm/mach-mx6/
Jaymin D
