Ethernet on i.MX RT 1170
gantener
I am required to conduct Ethernet debugging on an i.MX RT1170 development board running the RT-THREAD operating system. Within the i.MX RT1170 Processor Reference Manual, I've encountered several Ethernet options: ENET, ENET1G, and ENETQOS. Could you specify which of these is utilized for Gigabit Ethernet operations? It's mentioned that ENETQOS is an Intellectual Property (IP) from Synopsys.
here is the open source code
https://gitee.com/rtthread/rt-thread/blob/master/bsp/imxrt/libraries/drivers/drv_eth.c
xjy198903
ENET1G is used in rt1170 in rt-thread and it is Gigabit Ethernet
gantener
i want to use ENET_Qos ,Have you adapted under rt-thread? i did not find the code?will you please show me,thanks!
