Error: v4l2 capture: slave not found! on i.Mx6 with Android
2,482件の閲覧回数
marcoc
I'm using a sabre board i.mx6 with Android 13.4.1 pre-charged from Freescale.
The following are the timestamps when starts the init_process:
[ 11:25:49.785] Freeing init memory: 220K
[ 11:25:50.413] it: cannot find '/system/bin/gpu_init.sh', disabling 'gpu_init'
[ 11:25:50.421] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 11:25:50.457] android_usb: already disabled
[ 11:25:50.460] mtp_bind_config
[ 11:25:50.599] root@android:/ # input: eCompass as /devices/virtual/input/input5
[ 11:25:51.496] ERROR: v4l2 capture: slave not found!
[ 11:25:51.497] ERROR: v4l2 capture: slave not found!
[ 11:25:51.499] ERROR: v4l2 capture: slave not found!
[ 11:25:51.504] ERROR: v4l2 capture: slave not found!
[ 11:25:56.303] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 11:26:03.190] request_suspend_state: wakeup (3->0) at 16775179672 (1970-01-02 00:07:26.899817670 UTC)
[ 11:26:03.378] eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
[ 11:26:03.379] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11:26:03.424] acc_open
[ 11:26:03.424] acc_release
[ 11:26:07.038] CPU3: shutdown
Can you help me understand what are the causes of the problems highlighted for reduce the time of boot?
Regards Marco
ラベル(2)
863件の閲覧回数
megharajag
Hi Macro Cubisino,
Even I am facing the same issue, got any solution for this. If so please let me know, that would be helpful.
Thanks and Regards,
A G Megharaj
Edited :
One thing that you can check is that, is your camera's working properly. Also please see the kernel boot log. In my case the log shows
camera ov5642 is not found
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
camera ov5640_mipi is not found
so i am doubting the camera's. I think there may be some problem with camera. Please check your log.
