Encoding performence releted.
477件の閲覧回数
rajkishor
I am using imx6solo processor. I have some confusion regrading mjpeg and h264 encoder.
It takes around 50-60 millisecond.
I want improve my encoding performance, how i Can improve it encoding performence.
this is  tested on opencv.
Kindly suggest me the better way to do this.
thanks
Raj kishor
2 返答(返信)
408件の閲覧回数
joanxie
did you try to use gstreamer to test? the command like:
$GSTL filesrc location=test.yuv
! videoparse format=2 witdh=$WIDTH height=$HEIGHT framerate=30/1
! vpuenc_jpeg ! $MUXER ! filesink location=$output
The $MUXER can be set to qtmux, matroskamux, mp4mux, avimux, or flvmux.
408件の閲覧回数
rajkishor
Hi Joan Xie,
Actually I tested it with gst pipe line also. I guess that in pipe line also it take around 50-60 millisecond.
when i run  gst pipe line for just display image on autovideosink without encoding it takes 50-55 millisecond.
for example:   gst-launch-1.0 imxv4l2videosrc device=/dev/video0 ! autovideosink
And
when i run same pipe line with encoding , decode it through decodebin and display on autovideosink it takes 110-115.
millisecond.
for example: gst-launch-1.0 imxv4l2videosrc device=/dev/video0 !  imxvpuenc_mjpeg  ! decodebin ! autovideosink
and my requirement is the video should stream with maximum 80 millisecond delay.
Thank
Raj kishor
