I'm using MfgTools in Windows 10.
The MfgTool_MultiPanel(Library: 2.7.0) was performed by executing the mfgtool2-yocto-mx-sabresd-sdcard-sd4.vbs of L4.9.88_2.0.0_mfg-tool.
LOG : MfgTool_Initial.log
The SD4 slot on the MCIMX6SX-SDB board has an SDCARD loaded with binaries built with the yocto project (imx-4.9.88-2.0.0_ga/imx-linux-rocko).
The boot mode switch has been changed to Serial Download mode.
(BOOT_MODE0[D1] : ON / BOOT_MODE1[D2] : OFF))
Then, when boot up the board, Windows 10 installs the (Freescale SE Blank PELE) driver, but the MFG Tools are forced to terminate.
LOG : MfgTool_Crash.log
Please answer.
Thanks.
refer to the user guide, No dedicated boot DIP switches are reserved for serial download mode on i.MX 6 SABRE-SD and i.MX 6SoloLite boards, then when you connect your board with PC, check if you can find ""HID-compliant vendor-defined device" in the device manager, if you have issue for installing the driver, you need to check your PC, my win10 can install the driver successfully
Hi, Joan Xie.
Thank you for your answer.
I did the following, but I have a problem.
1. mode change
2. Run the MFG_Tool
3. Power on the EVB board.
4. The MFG_Tool is terminated...
2~4. screen capture : http://shorturl.at/acmLP
What are the differences causing this problem?
Please give me your opinion.
I appreciate it.
⨁ add contents : It works on other computers. it is the problem that only happens on my computer. In relation to that, is there anything wrong?
Hi, Joan Xie.
I tested it under various conditions.
Computer | OS | Result |
Desktop | Windows 10 | problem occurrence |
Notebook | Windows 7 | normal operation |
VMWare | Windows 10 | problem occurrence |
VMWare | Windows 7 | normal operation |
VMWare | Windows 8.1 | problem occurrence |
As shown in the table above, it seems to be the problem in Windows 10 & 8.1.
Windows 7 works fine.
Can you confirm the status quo?
I appreciate it.
⨁ add contents : There is also the forced shutdown problem in Linux.
The tested version is Ubuntu 12.04.3, 14.04.5, 16.04.6, 18.04 LTS.
Header 1 |
~/mfgtools$ sudo ./linux-runvbs.sh mfgtool2-yocto-mx-sabresd-sdcard-sd4.vbs Your Options: board: sabresd mmc: 3 sxuboot: sabresd sxdtb: sdb Ready to flash. Segmentation fault (core dumped) ~/mfgtools$ |
Hi, Joan Xie.
I got several windows 10 and tested them.
But it doesn't work.
Do you have a driver for Windows 10?
There is an event that failed migration in HID.
Please check again.
Thanks.
ps. The specification of my Windows 10 is "Windows 10 Pro / 1909 / 2020-02-24 / 18363.900"
⨁ add contents : The migration was resolved with the "sfc/scannow" command, but the MFGTool problem is not solved.
