Does vpuenc_h264 uses hardware encoding? how?
986 次查看
sagarmane
I'm using i.MX8M Plus EVK board. Does vpuenc_h264 uses hardware encoding in below example of gstreamer?
#gst-launch-1.0 videotestsrc num-buffers=300 ! video/x-raw,width=1920,height=1080,format=YUY2 ! queue ! vpuenc_h264 ! filesink location=output.h264
标记 (1)
972 次查看
joanxie
this uses HW(vpu) encoder
978 次查看
sagarmane
Hi @joanxie ,
Thanks for your response.
Yes this does work. My question was does vpuenc_h264 uses actual hardware available in board for encoding? or it is software encoding with gstreamer.
973 次查看
joanxie
981 次查看
joanxie
imx8mp should support this, you can try this, if you have any issue, pls tell me
