Does i.MX6q AUDMUX surpport this kind of route?
levisli
Hi all,
Now I receive BT phone i2s data from AUD6 pins(internal port 7),and I have a ssi playback channel on AUD4 pins(internal port 2).
Can I route the i2s signals from  AUD6 pins to AUD4 pins directly through some AUDMUX settings?
If yes,how about the settings?
Levisli
Labels (3)
levisli
Hi igorpadykov
I have read AN2628,it looks like the solution of my question is discribed in 3.4?
AN2628 just discribes this kind of scene but no description of how to config the relevant regisers.
Can you give me further infomation about how to config AUDMUX registers?
LevisLi
levisli
Hi igorpadykov
Thanks for your reply,I'll check this application and give a response later.
LevisLi
Hi Levisli
yes signals can be routed from AUD6 to AUD4, some examples can be found
in AN2628 Programming Audio Applications (described audmux module is the same as in i.MX6Q)
https://www.nxp.com/docs/en/application-note/AN2628.pdf
