Device tree setup for BCM4339 (brcmfmac)
1,360 次查看
marija_stojanov
Currently we are trying to enable wifi on iMX6ULL board via SD1 using Murata 1CK module (BT+WiFi) with V2 Adapter as interconnect. For this board we are using a customized BSP using the linux 4.19-rc4. I am trying to use the brcmfmac driver instead of bcmdhd.
I am curious if anyone else has worked and found a solution on the device tree setup for BCM4339 with the brcmfmac driver.
Thanks in advance for any suggestions / feedback.
wifi; bcm4339 wifi_module brcmfmac murata1ck murata imx6ull-evk
标签 (2)
976 次查看
romitchatterjee
Unfortunately, Linux 4.19-rc4 is still not supported by Murata. However, you can find Murata’s Linux solution for 4.1.15, 4.9.11, 4.9.88, and 4.9.123 on Murata’s GitHub (https://github.com/murata-wireless/meta-murata-wireless). Solution for 4.14.98 is also coming soon!
Thanks.
