Details of H.264 encoder support in i.MX8X
621件の閲覧回数
ko-hey
Senior Contributor II
Hi all,
I'm investigating a device spec of H.264 encoder in i.MX8X.
Could someone teach me following questions ?
Q1.What GOP structure of H.264 Encoder does i.MX8X support ?
Q2.What is the maximum GOP size of the H.264 Encoder (how long can the GOP be extended)?
Q3.What is the CPB (Coded Picture Buffer) size of the H.264 Encoder?
Q4.What is the output format of H.264 Encoder encoded data?
Q5.What is the supported encoding bit depth of H.264 Encoder?
Ko-hey
ラベル(2)
545件の閲覧回数
jamesbone
Since the device it is still under preproduction, we do not have much details I am doing some research internally to see, what I can answer from your questions.  I apologize for the inconvenience.
