Debugger required for i.MX6 solo
3,200 次查看
Bitesh
     I'm designing a custom board using i.MX6 processor. Just want to know which debugger should I buy for programming this processor ? Also If you can tell which IDE to use.
I have not done Processor programming before. For K-32 series Controller we were using J- link debugger and were using MCU Espresso IDE to debug step by step code.
Bitesh
3,181 次查看
JorgeCas
I hope you are doing well.
To debug your MPU it is necessary to use an external debugger probe. You can consult tested hardware on NXP's web page on section: Hardware -> Partners -> Test Accessories and Debugger.
I suggest you any debugger from MACRAIGOR Systems, Wind River or any of ARM. The guide to use it will be on selected external debugger web page.
Best regards.
Jorge.
3,182 次查看
JorgeCas
Best regards.
Jorge.
