Debug for M4 in imx8
647 次查看
Txaflin
I need to "debug" an application for the M4 on an imX8. Is this possible? Can it be done using an IDE, such as MCUXpresso?
594 次查看
Dhruvit
Hi @Txaflin,
I hope you are doing well.
Yes, It is possible to debug without IDE.
One can use J-Link GDB Server application to debug M4 core in i.MX8MM in the command line interface.
One can download it from https://www.segger.com/downloads/jlink/.
Please refer to 5.1 Linux OS host in Getting Started with MCUXpresso SDK for EVK-MIMX8 (Provided with SDK) to install the gcc toolchain, build, run & debug M4 core application.
Thanks & Regards,
Dhruvit Vasavada
5 回复数
612 次查看
_angelo_
M4 app can be written with all open tools, mainly gcc for cortex M and the ide you prefer, compiling by a simple makefile.
For startup .S files and linker scripts you can use those provided from the sdk, or write your own.
Also, i would not setup all jtag debugging if not really needed. Use some printf here and there to debug through the M4 uart console.
618 次查看
Txaflin
Thank you,
I'm using the i.mx8MM and I need to deploy an application for M4 Core.
The problem is that it is not possible for me to use IAR since I do not have a license.
Is it possible to configure any other IDE without a license?
595 次查看
Dhruvit
Hi @Txaflin,
Thanks & Regards,
Dhruvit Vasavada
590 次查看
Txaflin
Thanks!
I'll read and test this solution.
623 次查看
Dhruvit
Hi @Txaflin,
Yes, It is possible to debug i.MX8 using J-Link Plus.
One can use IAR Embedded Workbench ® for Arm and SEGGER J-Link software.
The IAR Embedded Workbench is an IDE
integrated with editor, compiler, debugger, and other components. The SEGGER J-Link software provides the driver for the J-Link Plus debugger probe and supports the device to attach, debug, and download.
Please specify the exact processor used for further info.
Thanks & Regards,
Dhruvit Vasavada
