DDR2 HW ZQ Calibration
1,552件の閲覧回数
yekta
Hi Community Members
I checked the DRAM_SDCKL_P and DRAM_SDCLK_N  signals in my HW ( no u-boot prompt) ,
the DC level of these signals should be VDDQ/2=Vref=0.9V , but I measured about 1.25Vdc.
Then I found an application note AN4466:imx53 DDR Calibration .Which says:
"Altough ODT activation is not typical for DDR2 ,it should be noted that ZQ calibration is recommended for setting the right bias for the DDR2 signals"
On another page : "Calibration sequence should be executed after the DDR memory has been initialized."
The DDR init code is in flash_header.S .
 I have to start the calibration by setting a bit of the ZQ ESDCTL register and wait until HW clears this bit(calibration done).
I dont know how to add this into flash_header.S.
Does  anybody know  any board example which uses DDR Calibration sequence ?
Or does anybody want to share his/her solution?
2 返答(返信)
776件の閲覧回数
Yuri
You are right :
According to section 3.1 (DDR2) of app note AN4466 “i.MX53 DDR Calibration” :
Although ODT activation is not typical for DDR2, it should be noted that the ZQ
calibration is recommended for setting the right VCC/2 bias for the DDR2 signals.
   Also, with the ZQ calibration, the drive strength can be calibrated too.
Please look at the next command from the enclosed DDR2 init script :
// Enable ZQ calibration to tightly control the impedance of the DDR IO pads
setmem /32 0x63fd9040 = 0x04b80003 // keep ZQ HW control values and enable it
The script may be used as an DDR2 init example.
776件の閲覧回数
HitoshiOgasawar
The information, thank you.
Because it is weak at English, it is being delayed by the understanding.
Thank you.
