Hi All,
We have using custom congatec imx8mp-cgtqx8p board which have HDMI and LVDS display connected.
LVDS display resolution is 1280x800
root@imx8mp-cgtqx8p:~# cat /sys/class/drm/card1-DPI-1/modes
1280x800
HDMI suppoered mode list :-
root@imx8mp-cgtqx8p:~# cat /sys/class/drm/card1-HDMI-A-1/modes
1920x1080
1920x1080
1920x1080
1920x1080
1280x1024
1280x1024
1280x960
1152x864
1280x720
1280x720
1280x720
1280x720
800x600
800x600
720x576
720x480
720x480
720x480
720x480
And I am trying to clone display from LVDS to HDMI but when I set custom resolution on my hdmi using below command.
setenv mmcargs "setenv bootargs pcie_cz_enabled=yes console=ttymxc1,115200 root=/dev/mmcblk1p2 rootwait rw video=HDMI-A-1:1280x800@60e"
It is not reflated on hdmi modes. This custom modes showing in cmdline.
HDMI-A-1/modes entry not showing new custom mode (1280x800)
Is this issue comes from bsp side or kernel side I don't know can someone help ?
Yocto build configuration is
Build Configuration:
BB_VERSION = "2.0.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mp-cgtqx8p"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "5.15-kirkstone"
TUNE_FEATURES = "aarch64 armv8a crc crypto"
weston.ini file configuration
[core]
#gbm-format=argb8888
#gbm-format=rgb565
idle-time=0
#use-g2d=1
xwayland=true
repaint-window=16
#enable-overlay-view=1
modules=screen-share.so
#[shell]
#size=1920x1080
[libinput]
touchscreen_calibrator=true
[output]
name=HDMI-A-1
clone-from=DPI-1
[output]
name=DPI-1
mode=1280x800@60
#[output]
#name=HDMI-A-2
#mode=off
# WIDTHxHEIGHT Resolution size width and height in pixels
# off Disables the output
# preferred Uses the preferred mode
# current Uses the current crt controller mode
#transform=rotate-90
[screen-share]
command=/usr/bin/weston --backend=rdp-backend.so --shell=fullscreen-shell.so --no-clients-resize --rdp-tls-cert=/etc/freerdp/keys/server.crt --rdp-tls-key=/etc/freerdp/keys/server.key
start-on-startup=true
HI @joanxie
Thanks for your support. Yes you are right I am trying to set custom resolution for HDMi display(1280x800) to clone LVDS display which is fixed resolution(1280x800).
As you said imx8mp not support clone mode. when I check other board (toradex verdin imx8mp) the clone mode is working fine on that. It have two HDMI port. But also if tried to set custom resolution on both HDMI the clone mode is not working in toradex.
I am confuse here If clone mode is not supported in imx8mp then how toradex board clone works? also same time when I set custom resolution(1280x800) on toradex board the clone is not working.
>what backend do they use? do they use weston? current bsp uses weston, which couldn't support clone mode (LVDS+HDMI) as default, customer needs change the weston source code by themselves, I just say default nxp bsp couldn't support this
