Configure the Android linux kernel
2,955件の閲覧回数
jiongzhongliu
I have a question about configure Android kernel. I entery the kernel dir ANDROID_DIR/kernel_imx, and run " make menuconfig" ,and config the kernel ,then save the config file. and I go to the android top dir to "make bootimage",after make bootimage, I go to kernel_imx dir and "make menuconfig" again, and I found the config file back to its origial state.How can it happy? Is repressent that my own .config file didn't work?
ラベル(2)
3 返答(返信)
2,637件の閲覧回数
Rita_Wang
Hi jiongzhong liu,
Here could you tell me which android BSP and which board are you using ?
Have an nice day
Dan
2,637件の閲覧回数
jiongzhongliu
my board is a custom board base imx6qsabresd.and use android4_2_2_1_1 bsp.Thanks
2,637件の閲覧回数
Rita_Wang
Hi jiongzhong liu,
You can try to clean your original build first and then rebuild it.
Have a nice day
Dan
