In my custom board, it only contains one Ethernet_EQOS, but would like to remove the TSN supported feature, what should i need to change in dts or other files ?
Solved! Go to Solution.
Hi @Jimmychea
I would like to use the eqos node, but i don't want the TSN feature, is that possible to do it ?
