Cannot download BSP 3.10.17 (Yocto)
frankschmid
I tried to download the BSP source 3.10.17 for Yocto with the command (as recommended in the documentation):
repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.10.17-1.0.2_ga
But it immediately fails with:
fatal: Cannot get https://gerrit.googlesource.com/git-repo/clone.bundle
fatal: error [Errno -2] Name or service not known
The clone.bundle file does not exist (404). How can I get the BSP? Is it possible to clone
it without the repo tool?
Labels (3)
Tags (2)
Yuri
  I will send You the link to download the package.
Yuri
Yuri
Yuri
matthiasheise
Hello Yuri,
same problem here, I'm trying to follow this guide:
Freescale Semiconductor
User's Guide
Document Number:IMXLXYOCTOUG
Rev L3.10.17_1.0.0-ga, 05/2014
and also get this error :
:~/fsl-release-bsp$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.10.17-1.0.0_ga
couldn't you share the correct link here ?
Thanks very much,
best regards,
Mat
Yuri
   Please try the recent BSP, the document, linked
below explains how to do it.
http://cache.freescale.com/files/32bit/doc/support_info/IMX6YOCTOPATCHRN.pdf
~Yuri.
matthiasheise
this is what I get...
* [new tag]     v1.9.0 -> v1.9.0
* [new tag]     v1.9.1 -> v1.9.1
* [new tag]     v1.9.2 -> v1.9.2
* [new tag]     v1.9.3 -> v1.9.3
* [new tag]     v1.9.4 -> v1.9.4
* [new tag]     v1.9.5 -> v1.9.5
* [new tag]     v1.9.6 -> v1.9.6
Get https://git.freescale.com/imx/fsl-arm-yocto-bsp.git
  % Total% Received % Xferd  Average Speed   TimeTime Time  Current
                             Dload  Upload   Total   SpentLeft  Speed
  0 00 00 0 --:--:--  0:00:01 --:--:-- 0
curl: (22) The requested URL returned error: 404
Server does not provide clone.bundle; ignoring.
fatal: https://git.freescale.com/imx/fsl-arm-yocto-bsp.git/info/refs not found: did you run git update-server-info on the server?
fatal: cannot obtain manifest git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
matthiasheise
any new ideas to that? or is maybe the reason that I use https links instead of git?
Yuri
Yes, please use git - exactly as recommended in the notes.
~Yuri.
shengqiangai
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
this cmd always time out ,could you send me one
saurabh206
Senior Contributor III
Hi shengqiang
You can try this one.
curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ./repo
shengqiangai
I am sorry ,chinese user  can't visit the google website. I follow the <<Freescale_Yocto_Project_User's_Guide.pdf>>,but i can't get  repo:
$ mkdir ~/bin (this step may not be needed if the bin folder already exists)
$ curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
$ chmod a+x ~/bin/repo
