One of my board(imx6 solo) detect the cpu die temperature wrong, below is some key logs:
U-Boot 2018.03 (Oct 17 2019 - 10:39:25 +0800), Build: jenkins
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 98C
Reset cause: POR
Model: Freescale i.MX6 DualLite SABRE Smart Device Board
Board: MX6-SabreSD
DRAM: 1 GiB
in kernel log:
[ 69.283725] thermal thermal_zone0: critical temperature reached (101 C), shutting down
[ 74.483731] thermal thermal_zone0: critical temperature reached (101 C), shutting down
[ 75.523704] thermal thermal_zone0: critical temperature reached (102 C), shutting down
I would like to know if the OCOTP affect the temperature detection?
And the board is abnoraml now, it cannot boot up without USB.
I suspect the problem is more like the hardware on this board work abnoraml. But I want to double check is the OCOTP value will affect the temperature?
Thanks in advance.
Jane
Hi Jane
one can check temperature calibration app note
i.MX 6 Temperature Sensor Module - Application Note
Calibration coefficients are stored in fuses.
Also one can try with different samples and if issue occurs only with specific batch
work with local marketing office for FA procedure.
Hi igor,
Does the 0x4E0[31:0] (Analog_temp_sense[31:0]) had been calibrated before the chip shipped?
Is there any possible to make the temperature wrong when writing fuse wrong?
This abnormal chip was working well before, After fused it detects the temperature wrong. But I am not sure the root cause is fusing wrong or physical damaged.
BR,
Jane
Hi Jane
>How could I know the value in our board is right?
sorry there is no way to know. Only running nxp software described on
Hi igorpadykov,
one of my chipset detect temperature wrong, the log in uboot is "CPU: Industrial temperature grade (-40C to 105C) at 98C", but use the thermal imager to ensure it only 40C now.
So I would like to know if it caused by wrong value of 0x4E0[31:0] (Analog_temp_sense[31:0]).
Is there any way to find the root cause?
BR,
Jane
