CAAM error in non-secure linux kernel
1,273 次查看
myungjinhwang
Dear freescale team.
I have questions about CAAM in i.mx6qsabreauto board.
I changed linux kernel to work in non-secure mode. of course, modified CSU to access peripherals in non-secure kernel.
But it occurs caam errors when booting kernel.
I think that i need to configure "Job Ring MID Register (JRMIDR)", "DECO MID Register (DECOxMID)"  in the guide of IMX6DQ6SDLSRM_security.pdf
i really don't know how to configure it well. it's not easy to understand the pdf guide file.
if i'm right,  is thers some  reference code?
And i saw "ls1021x_config_caam_stream_id()" in u-boot.
It says for supporting for initializing CAAM's stream id.
I'm not sure but the function is for adjusting JRMIDR, DECOxMID values?
Thank you.
627 次查看
Yuri
  I hope the following helps How to read/write CAAM registers in non-secure world kernel?
Yuri
627 次查看
myungjinhwang
Hello Yuri.
Thanks for your supports.
I'm still having same problems with the link that you attached.
I also have set the CSU_CSL17 register to 0x00ff00ff so that CAAM can be accessible in both non-secure and secure worlds.
and MPROTx values is as bellow :
0207C000 : 0x77777777 0x77777777
0217C000 : 0x77777777 0x77777777
But all of register values of caam are 0 in svc/non-secure mode.
i can see correct register values only in secure mode.
I have set the CSU and AIPTZ registers values.
wonder that caam might work with non-secure mode in imx6.
what is the problem ? could you give some guides in detailed ?
Have a great day
627 次查看
mach
Hello MyungJin:
I have the same problem as you. Have you solved it?
