Build ltib error......
1,252 次查看
sangjinhong
I'm sure that I was successful to build ltib for i.MX 6 previous week.
I don't know why???
Please help me !!!
However, I tried to build ltib this monday, but I couldn't do that.
There was build error.
I referenced i.MX_6Dual6Quad_SABRE-SD_Linux_User's_Guide.pdf document.
I ran the following commands:
$ tar zxvf L3.0.35_4.1.0_130816_source.tar.gz
$ ./L3.0.35_4.1.0_130816_source/install
$ cd <LTIB directory>
$ ./ltib -m config
there was a error like the following:
$ ./ltib -m config
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
/home/istech/dev/freescale/dev_env/ltib/host_config.log
Exiting on error or interrupt
Please see >> /home/istech/dev/freescale/dev_env/ltib/host_config.log for details
host_config is like the following:
Processing platform: Host support packages
using /home/istech/dev/freescale/dev_env/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
4 回复数
956 次查看
sangjinhong
I resolved the problem after I installed texinfo package.
$ sudo apt-get install texinfo
I don't exactly know why???
956 次查看
Rita_Wang
Hi sangjin,
When you build the newest BSP, the packages texinfo and texlive are required by LTIB. Details are  "Setting_Up_LTIB_host.pdf" you can have a look.
And you can also take Re: Linux build issue (L3.0.35_4.0.0) for reference.Hope this can help you ~~
Best Regards
Dan
956 次查看
Rita_Wang
Hi sangjin,
When you rebuild BSP in ltib, make sure that Remove all previously-installed packages from /opt/freescale/pkgs/.
As Leo said above. You can have a try:smileyhappy:~~
Best Regards
Dan
956 次查看
LeonardoSandova
Specialist I
have you done the suggestion on the log?
