Build fsl-image-gui on SD card for Sabrelite
1,194 次查看
philippeballeyd
Hi everyone
I'm trying to build the fsl-image-gui from the dylan branch on the SabreLite.
Building the image didn't seem to be a problem (followed this link: http://www.ossystems.com.br/blog/2013/04/15/yocto-with-boundary-devices-nitrogen6x-5-steps-only.html )
i copied the image to the sd card with the following command:
$ sudo dd if=fsl-image-gui-nitrogen6x.sdcard of=/dev/mmcblk0 bs=1M && sync
I'm having trouble to make the SabreLite boot on the SD3 slot.
I tried by following the first part of this tutorial: https://wiki.linaro.org/Boards/MX6QSabreLite
But now i can't see any u-boot prompt when i start the board.
Do i have to change the boot pins? Did i have to add u-boot to my sd card?
Any pointers would be of great help.
Thank you.
标签 (3)
770 次查看
igorpadykov
Hi Philippe
seems this image already contains Uboot,
however for specifics of this board I would suggest to post
on boundary devices forum
http://boundarydevices.com/community/
770 次查看
EricNelson
Senior Contributor II
Hi Phillipe,
The dylan branch is quite old (current is "dizzy"), and you're probably running into a bug in the boot script.
If you can use 'strings' to look at the file 6x_bootscript in the boot partition, you'll likely see something like
this:
if test "sata" = "${dtype}" ; then
  setenv bootargs "$bootargs root=/dev/sda2" ;
else
  setenv "bootargs $bootargs root=/dev/mmcblk0p2" ;
fi
Note the misplaced quote on line 4 above (should be after bootargs and before $bootargs).
If that's the case, replacing that boot script with the attached version will fix the issue.
This is from the "production" branch of our U-Boot tree:
     u-boot-imx6/6x_bootscript-yocto.txt at production · boundarydevices/u-boot-imx6 · GitHub
You can use our on-line boot script compiler to quickly customize things if needed:
     http://git.boundarydevices.com/bootscript.php
770 次查看
philippeballeyd
I'll switch to the dizzy branch. No point using an old one.
I think i will have to unbrick the board, since i don't really know where i failed :/
I'll keep you updated.
Thank you
