Build a 32biti rootfs for imx-yocto-L4.14.98_2.0.0_ga
911件の閲覧回数
westbrook
Hi Guys,
I am using imx8mm with imx-yocto-L4.14.98_2.0.0_ga.
I need to built an 32bit rootfs from imx-yocto-L4.14.98_2.0.0_ga. The default gives me a aarch64  64bit rootfs.
How to set to build an 32bit rootfs?
Thank you in advance.
BR,
Xiao
ラベル(3)
3 返答(返信)
833件の閲覧回数
igorpadykov
Hi Xiao
one can look at AN12212
Software Solutions for Migration Guide from Aarch32 to Aarch64
833件の閲覧回数
westbrook
Hi Igor,
Thanks for your quick reply.
I have tried the compatible mode, but it seems that we still need 32bit imx-gpu-viv for imx8mm, where can we get this ?
BR,
Xiao
833件の閲覧回数
igorpadykov
Hi Xiao
one can also check sect.5.6.9 Multilib enablement Yocto Guide included in
Linux 4.14.98_2.2.0 Documentation
