Bug with fsl-arm-yocto-bsp.git repo's branches ?
1,523 次查看
TeleLaci
Hi all,
I do this :
$ mkdir fsl-arm-yocto-bsp-3.10.17-1.0.2
$ cd fsl-arm-yocto-bsp-3.10.17-1.0.2
$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.10.17-1.0.2_ga
$ repo sync
...dum da dum...
$ cd sources/meta-fsl-arm/recipes-graphics/gpu-viv-bin-mx6q
$ ls -l
total 24
drwxrwxr-x 2 tele tele  4096 Nov  2 05:57 gpu-viv-bin-mx6q
-rw-rw-r-- 1 tele tele   310 Nov  2 05:57 gpu-viv-bin-mx6q_3.10.9-1.0.0-hfp.bb
-rw-rw-r-- 1 tele tele   310 Nov  2 05:57 gpu-viv-bin-mx6q_3.10.9-1.0.0-sfp.bb
-rw-rw-r-- 1 tele tele 11068 Nov  2 05:57 gpu-viv-bin-mx6q.inc
hmmmmm....
$ cd ../gpu-viv-g2d
$ ls -l
total 8
-rw-rw-r-- 1 tele tele  307 Nov  2 05:57 gpu-viv-g2d_3.10.9-1.0.0.bb
-rw-rw-r-- 1 tele tele 1103 Nov  2 05:57 gpu-viv-g2d.inc
hmmm...hmmm
Where are the 3.10.17-1.0.2 binaries if not in the imx-3.10.17-1.0.2_ga branch ?
Laci
943 次查看
LaurenPost
Change directory to meta-fsl-bsp-release/imx/meta-fsl-arm/recipe-graphics/gpu-viv-bin-mx6q
You are looking at the community side on the dora branch which is the older version.
This has already been upstreamed into the master branch of community (and will be moved into dizzy branch soon) so you have option of using the community only if you want a newer Yocto base.
944 次查看
LaurenPost
943 次查看
gusarambula
Thank you, Lauren, for the help!
943 次查看
TeleLaci
Wow, thank you. It seems I was lost in the woods.:smileyhappy:
