BQ27621 integrated with IMX6 solo lite
764 次查看
vinothrajm
I am trying to  integrate the BQ27621 with IMX6 Solo Lite in android platform.
I get the driver for BQ27621 from below link:
linux-bq27xxx/bq27x00_battery.c at master · aneeshv/linux-bq27xxx · GitHub
And i added the driver and compile it .
When i booted the board and it works fine it shows the battery capacity, percentage etc.
But when I switch on and load the Wif modulei of the board and it goes  KERNEL PANIC .
I am using  both below versions. Both shows same problem.
I  attached the boot log file. Please find it . OR ANY other driver file for  BQ27621,Please suggest it. !
Original Attachment has been moved to: one.txt.zip
标签 (2)
标记 (2)
538 次查看
jimmychan
Do you mean the Wifi is working fine if not load the BQ27621 driver? If it is the case, I think you may need to add some printk in the driver to see which part make the kernel panic.
