Dear NXP,
I am working on IMX8QM with Android 9. I needs to configure usb stick on static mount point.
Currently,
/dev/block/vold/public:8,1 3918844 2993196 925648 77% /mnt/media_rw/2A61-DD07
Needs to configure,
/dev/block/vold/public:8,1 3918844 2993196 925648 77% /mnt/media_rw/USB
Thanks & Regards,
VinothS
解決済! 解決策の投稿を見る。
Done Static point in the following source code,
system/vold/model/PublicVolume.cpp
Current configuration,
// Use UUID as stable name, if available std::string stableName = getId(); if (!mFsUuid.empty()) { stableName = mFsUuid; } mRawPath = StringPrintf("/mnt/media_rw/%s", stableName.c_str());
New Configuration,
// Use UUID as stable name, if available std::string stableName = getId(); if (!mFsUuid.empty()) { stableName = mFsUuid; } mRawPath = StringPrintf("/mnt/media_rw/USB");
Thanks & Regards,
VinothS
New Configuration,
Thanks & Regards,
VinothS
Once usb stick detected,
create sda1 ,
after check I got,
mek_8q:/sdcard # df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1777588 1189664 587924 67% /
tmpfs 2918920 488 2918432 1% /dev
tmpfs 2918920 0 2918920 0% /mnt
/dev/block/mmcblk0p12 249828 58936 190892 24% /vendor
/dev/block/mmcblk0p14 9086336 967628 8118708 11% /data
/data/media 9086336 967628 8118708 11% /mnt/runtime/default/emulated
/dev/block/vold/public:8,1 3918844 1311400 2607444 34% /mnt/media_rw/2A61-DD07
I needs to configure static point instead of some random number (/mnt/media_rw/2A61-DD07).
If it possible, Please provide the configuration and files with respect to Android 9 with IMX8QM
Thanks & Regards,
VinothS
You can assign the mountpoint in fstab.
Thank you Victor,
Will you please give example. I tried but, I am unable to do it. Maybe I miss something.
Thanks & Regards,
VinothS,
