Any ideas why PPP w/ 3G modem would work in one Yocto image and not another?
1,024件の閲覧回数
patrickphilp
We've got a custom i.MX6 platform that we've designed, and we're adding 3rd party PCIe 3G modem cards to the boards.
When I build a Yocto image with the fsl-image-gui recipe (with ppp added), the PPP link will start up but shortly after authenticating, the link will drop with the following debug messages from PPP:
sent [LCP EchoReq id=0x1 magic=0x9950d399]
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
rcvd [LCP EchoRep id=0x1 magic=0x96a24aa4]
rcvd [LCP TermReq id=0x4]
LCP terminated by peer
sent [LCP TermAck id=0x4]
Modem hangup
Connection terminated.
However, the exact same hardware, using an image produced with the core-image-full-cmdline recipe works just fine - the PPP link is established and works without problems.
The PPP option and chatscript files are identical, and the Linux kernel is built with the exact same configuration.
Any suggestions on where to look in the various image recipes would be greatly appreciated.
pjp
ラベル(3)
2 返答(返信)
619件の閲覧回数
igorpadykov
Hi Patrick
graphic rich gui and especially video may consume great
bus bandwidth, not leaving sufficient room for normal modem
operation, causing link timeouts.
619件の閲覧回数
patrickphilp
Actually, it turns out that connman was terminating the connection shortly after it was made. When connman was disabled and unable to kill the ppp connection, it works fine.
