Android Automotive OS 10 iMX8QM MEK Dual LVDS Panel Error
5,697 次查看
cbl
Contributor V
I want to drive my dual channel LVDS panel with Android Automotive OS 10 on iMX8QM MEK.
I added the nodes I got from "imx8qm-mek-jdi-wuxga-lvds1-panel.dts" to drive my dual channel LVDS panel to the attached "imx8qm-mek-car2.dts".
But in this case I couldn't get any image from my panel.
Can you help with this?
By applying the above changes, I drove the same LVDS panel Native Android 10 and got an image.
But with Android Automotive OS 10 I can't get image from my LVDS panel.
Device Tree:
* Copyright 2020 NXP
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* as published by the Free Software Foundation; either version 2
* of the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
#include "imx8qm-mek-rpmsg.dts"
&i2c0 {
clock-frequency = <1000000>;
isl29023@44 {
status = "disabled";
fxos8700@1e {
fxas2100x@20 {
/* max7322 used for fec2 */
gpio@68 {
mpl3115@60 {
&i2c1 {
&i2c2 {
&i2c3 {
&i2c_mipi_csi0 {
&i2c1_lvds0 {
clock-frequency = <500000>;
&i2c1_lvds1 {
&i2c0_mipi0 {
&mipi0_dphy {
&mipi0_dsi_host {
&i2c0_mipi1 {
&mipi1_dphy {
&mipi1_dsi_host {
&pwm_lvds0 {
&pwm_lvds1 {
&lvds_backlight0 {
&lvds_backlight1 {
&i2c0_hdmi {
&usdhc2 {
&amix {
&asrc0 {
&jpegdec {
&jpegenc {
&wm8960 {
quick-probe;
&vehicle_core {
status = "okay";
&sata {
&pcieb{
/* used for can io expander */
&pca6416 {
&fec1 {
&fec2 {
&sai6 {
&sai7 {
&emvsim0 {
&flexspi0 {
&crypto {
firmware {
android {
fstab {
/delete-node/ system;
vendor {
compatible = "android,vendor";
/* default emmc node used for GSI */
dev = "/dev/block/platform/bus@5b000000/5b010000.mmc/by-name/vendor";
/* sd card node which used if androidboot.boot_device_root=mmcblk1 */
dev_mmcblk1 = "/dev/block/platform/bus@5b000000/5b020000.mmc/by-name/vendor";
/* emmc node which used if androidboot.boot_device_root=mmcblk0 */
dev_mmcblk0 = "/dev/block/platform/bus@5b000000/5b010000.mmc/by-name/vendor";
type = "ext4";
mnt_flags = "ro,barrier=1,inode_readahead_blks=8";
fsmgr_flags = "wait,slotselect,avb";
product {
compatible = "android,product";
dev = "/dev/block/platform/bus@5b000000/5b010000.mmc/by-name/product";
dev_mmcblk1 = "/dev/block/platform/bus@5b000000/5b020000.mmc/by-name/product";
dev_mmcblk0 = "/dev/block/platform/bus@5b000000/5b010000.mmc/by-name/product";
type = "ext4";
lvds1_panel {
compatible = "jdi,tx26d202vm0bwa";
backlight = <&lvds_backlight1>;
port {
panel_lvds1_in: endpoint {
remote-endpoint = <&lvds1_out>;
&ldb1_phy {
&ldb1 {
&i2c1_lvds0 {
lvds-to-hdmi-bridge@4c {
/delete-node/ &it6263_1_in;
&ldb2 {
status = "okay";
fsl,dual-channel;
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
status = "okay";
port@1 {
reg = <1>;
lvds1_out: endpoint {
remote-endpoint = <&panel_lvds1_in>;
Boot Log:
U-Boot SPL 2019.04 (Nov 30 2022 - 14:39:05 +0300)
Normal Boot
Trying to boot from MMC1
Authentication key not yet programmed
keyslot package magic error, do nothing here!
Booting from bootloader_a...
UU
welcome to lk/MP
boot args 0x2000000 0xfe000000 0x2000 0x0
initializing trusty (Built: 17:43:29 Jun 15 2020)
Initializing Trusted OS SMC handler
avb: Initializing AVB App
hwcrypto: Initializing
hwrng_caam: Init HWRNG service provider
hwrng_srv: Start HWRNG service
hwcrypto_caam: Init HWCRYPTO service provider
hwcrypto_srv: Start HWCRYPTO service
hwkey_caam: Init HWKEY service provider
hwkey_caam: 183: Invalid magic, unpack key package fail.
hwkey_srv: Start HWKEY service
hwcrypto: enter main event loop
trusty_gatekeeper: Initializing
MMC: FSL_SDHC: 0
In: serial@5a060000
Out: serial@5a060000
Err: serial@5a060000
flash target is MMC:0
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
INFO Initializing Trusty IPC device
INFO Initializing RPMB storage proxy service
ss: get_rpmb_auth_key: failed to get key: -2
ss: proxy_connect: can't get storage auth key: (-2)
ss-ipc: 105: do_connect: failure initializing channel state (1001)
rpmb_proxy.c:312: ERROR rpmb_storage_proxy_init: unexpected proxy channel close
libtipc.c:93: ERROR Initlializing RPMB storage proxy service failed (-8)
INFO Initializing Trusty Hardware Crypto client
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
Verifying slot _a ...
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:764: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
verify FAIL, state: UNLOCK
boot 'boot_a' still
Kernel load addr 0x80280000 size 8995 KiB
kernel @ 80280000 (9210729)
ramdisk @ 86400000 (6081943)
fdt @ 83e80000 (127339)
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
ipc_dev.c:306: ERROR trusty_ipc_dev_close: secure OS returned (-7)
## Flattened Device Tree blob at 83e80000
Booting using the fdt blob at 0x83e80000
Using Device Tree in place at 0000000083e80000, end 0000000083ea216a
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000100 [0x410fd082]
[ 0.000000] Linux version 5.4.24-dirty (tttech@tttech-pc) (Android (5271481 based on r349610) clang version 8.0.8 (https://android.googlesource.com/toolchain/clang 4dba9ad555eabb40b39dc53c12d09423e9faea7b) (https://android.googlesource.com/toolchain/llvm ab552995647d484a712bf15f77e6c6f4e8ac532b) (based on LLVM 8.0.8svn)) #7 SMP PREEMPT Wed Nov 30 14:39:11 +03 2022
[ 0.000000] Machine model: Freescale i.MX8QM MEK
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node rpmsg_dma@0x90400000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 1184 MiB at 0x0000000096000000
[ 0.000000] earlycon: lpuart32 at MMIO 0x000000005a060000 (options '')
[ 0.000000] printk: bootconsole [lpuart32] enabled
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 22 pages/cpu s50776 r8192 d31144 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1483272
[ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon androidboot.console=ttyLP0 androidboot.xen_boot=default init=/init androidboot.hardware=freescale firmware_class.path=/vendor/firmware loop.max_part=7 androidboot.fbTileSupport=enable cma=1184M@0x960M-0xe00M transparent_hugepage=never androidboot.lcd_density=240 androidboot.primary_display=imx-drm androidboot.wificountrycode=CN galcore.contiguousSize=33554432 video=HDMI-A-2:d buildvariant=userdebug androidboot.serialno=0514200e82964887 androidboot.btmacaddr=05:14:20:0e:82:96 androidboot.soc_type=imx8qm androidboot.boot_device_root=mmcblk0 androidboot.boottime=1BLL:0,1BLE:2934,KL:0,KD:0,AVB:346,ODT:0,SW:0 androidboot.bootreason=reboot androidboot.verifiedbootstate=orange androidboot.flash.locked=0 androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3095928 verity 1 PARTUUID=77007a91-b44b-4afd-9642-8ddbd67d6e01 PARTUUID=77007a91-b44b-4afd-9642-8ddbd67d6e01 4096 4096 386991 386991 sha1 9e2d846c209b792ec1194e97f2d4c0d9eeef12d9 b
[ 0.000000] device-mapper: init: will configure 1 devices
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0xfa000000-0xfe000000] (64MB)
[ 0.000000] Memory: 4605572K/6027264K available (11132K kernel code, 1010K rwdata, 3684K rodata, 2240K init, 498K bss, 209276K reserved, 1212416K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 512 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 100 region 0:0x0000000051b80000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] random: get_random_bytes called from start_kernel+0x1c8/0x37c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000002] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.008271] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.018245] pid_max: default: 32768 minimum: 301
[ 0.022882] LSM: Security Framework initializing
[ 0.027481] SELinux: Initializing.
[ 0.031009] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.038528] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.070529] ASID allocator initialised with 32768 entries
[ 0.083598] rcu: Hierarchical SRCU implementation.
[ 0.096578] EFI services will not be available.
[ 0.108782] smp: Bringing up secondary CPUs ...
[ 0.145916] Detected PIPT I-cache on CPU1
[ 0.145940] GICv3: CPU1: found redistributor 101 region 0:0x0000000051ba0000
[ 0.145958] CPU1: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.179175] CPU features: detected: ARM erratum 845719
[ 0.179189] Detected VIPT I-cache on CPU2
[ 0.179210] GICv3: CPU2: found redistributor 0 region 0:0x0000000051b00000
[ 0.179241] CPU2: Booted secondary processor 0x0000000000 [0x410fd034]
[ 0.209969] Detected VIPT I-cache on CPU3
[ 0.209983] GICv3: CPU3: found redistributor 1 region 0:0x0000000051b20000
[ 0.210000] CPU3: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.241995] Detected VIPT I-cache on CPU4
[ 0.242010] GICv3: CPU4: found redistributor 2 region 0:0x0000000051b40000
[ 0.242027] CPU4: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.274015] Detected VIPT I-cache on CPU5
[ 0.274031] GICv3: CPU5: found redistributor 3 region 0:0x0000000051b60000
[ 0.274048] CPU5: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.274138] smp: Brought up 1 node, 6 CPUs
[ 0.370067] SMP: Total of 6 processors activated.
[ 0.374756] CPU features: detected: 32-bit EL0 Support
[ 0.379887] CPU features: detected: CRC32 instructions
[ 0.385043] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.393354] CPU: All CPU(s) started at EL2
[ 0.397449] alternatives: patching kernel code
[ 0.402170] CPU5: update max cpu_capacity 1024
[ 0.402509] devtmpfs: initialized
[ 0.414038] CPU1: update max cpu_capacity 1024
[ 0.418050] Initilizing CustomIPI irq domain
[ 0.426402] Registered cp15_barrier emulation handler
[ 0.431431] Registered setend emulation handler
[ 0.436181] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.445682] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.464790] pinctrl core: initialized pinctrl subsystem
[ 0.469992] DMI not present or invalid.
[ 0.473638] NET: Registered protocol family 16
[ 0.478169] schedtune: configured to support 5 boost groups
[ 0.487201] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.492962] audit: initializing netlink subsys (disabled)
[ 0.498435] audit: type=2000 audit(0.392:1): state=initialized audit_enabled=0 res=1
[ 0.506089] cpuidle: using governor menu
[ 0.510183] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.516899] imx mu driver is registered.
[ 0.520668] imx rpmsg driver is registered.
[ 0.601516] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.607896] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.614562] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.621250] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.629762] cryptd: max_cpu_qlen set to 1000
[ 0.643651] ACPI: Interpreter disabled.
[ 0.661678] iommu: Default domain type: Translated
[ 0.672706] vgaarb: loaded
[ 0.675233] SCSI subsystem initialized
[ 0.678972] usbcore: registered new interface driver usbfs
[ 0.684305] usbcore: registered new interface driver hub
[ 0.689608] usbcore: registered new device driver usb
[ 0.695497] mc: Linux media interface: v0.10
[ 0.699440] videodev: Linux video capture interface: v2.00
[ 0.705161] trusty trusty: trusty version: Built: 17:43:29 Jun 15 2020
[ 0.711426] trusty trusty: selected api version: 3 (requested 3)
[ 0.744331] Advanced Linux Sound Architecture Driver Initialized.
[ 0.763873] imx-scu scu: NXP i.MX SCU Initialized
[ 0.780083] random: fast init done
[ 0.795306] imx-rpmsg 90000000.rpmsg0: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.808989] uart4_clk: failed to attached the power domain -2
[ 0.831170] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.860352] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 0.866516] imx-rpmsg 90100000.rpmsg1: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.875912] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 0.883541] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 0.885527] virtio_rpmsg_bus virtio2: creating channel rpmsg-vehicle-channel addr 0x1
[ 0.897554] virtio_rpmsg_bus virtio2: creating channel rpmsg-i2c-channel addr 0x2
[ 0.905733] i2c-rpmsg virtio2.rpmsg-i2c-channel.-1.2: new channel: 0x400 -> 0x2!
[ 0.960518] imx_rpmsg_i2c bus@5a000000:i2c-rpbus-1: add I2C adapter i2c-rpmsg-adapter successfully
[ 1.006445] imx8qm-pinctrl scu:pinctrl: Invalid fsl,pins or pins property in node /scu/pinctrl/wifi_initgrp
[ 1.015937] imx8qm-pinctrl scu:pinctrl: initialized IMX pinctrl driver
[ 1.030189] clocksource: Switched to clocksource arch_sys_counter
[ 1.036102] VFS: Disk quotas dquot_6.6.0
[ 1.039885] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.046859] pnp: PnP ACPI: disabled
[ 1.175123] thermal_sys: Registered thermal governor 'step_wise'
[ 1.175125] thermal_sys: Registered thermal governor 'power_allocator'
[ 1.186350] NET: Registered protocol family 2
[ 1.197131] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.205464] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.213555] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.221227] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.227529] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.234305] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.241611] NET: Registered protocol family 1
[ 1.247480] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.272128] Initialise system trusted keyrings
[ 1.276312] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.284747] Registering sdcardfs 0.1
[ 1.288071] fuse: init (API version 7.31)
[ 1.301982] Key type asymmetric registered
[ 1.305738] Asymmetric key parser 'x509' registered
[ 1.310617] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 1.317983] io scheduler mq-deadline registered
[ 1.322502] io scheduler kyber registered
[ 1.332921] i2c i2c-2: LPI2C adapter registered
[ 1.339813] i2c i2c-3: LPI2C adapter registered
[ 1.382762] i2c i2c-4: LPI2C adapter registered
[ 1.387659] gpio-494 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 1.396290] imx-lpi2c 5a810000.i2c: using scl,sda for recovery
[ 1.403979] i2c i2c-5: LPI2C adapter registered
[ 1.408432] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 1.417606] imx6q-pcie 5f000000.pcie: couldn't get pcie-phy
[ 1.423014] usb_phy_generic bus@5b000000:usb3-phy: bus@5b000000:usb3-phy supply vcc not found, using dummy regulator
[ 1.423448] imx6q-pcie 5f000000.pcie: No cache used with register defaults set!
[ 1.443805] imx6q-pcie 5f000000.pcie: host bridge /bus@5f000000/pcie@0x5f000000 ranges:
[ 1.451521] imx6q-pcie 5f000000.pcie: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 1.458872] imx6q-pcie 5f000000.pcie: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 1.485600] i2c i2c-6: LPI2C adapter registered
[ 1.513176] mxs-dma 5b810000.dma-apbh: initialized
[ 1.519102] Bus freq driver module loaded
[ 1.527919] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 40, base_baud = 5000000) is a FSL_LPUAR[ 1.537071] printk: console [ttyLP0] enabled
[ 1.545494] printk: bootconsole [lpuart32] disabled
[ 1.556206] fsl-lpuart 5a060000.serial: DMA tx channel request failed, operating without tx DMA
[ 1.564935] fsl-lpuart 5a060000.serial: DMA rx channel request failed, operating without rx DMA
[ 1.574204] imx6q-pcie 5f000000.pcie: PCIe PLL locked after 0 us.
[ 1.574236] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 41, base_baud = 5000000) is a FSL_LPUART
[ 1.591874] arm-smmu 51400000.iommu: probing hardware configuration...
[ 1.598422] arm-smmu 51400000.iommu: SMMUv2 with:
[ 1.603126] arm-smmu 51400000.iommu: stage 1 translation
[ 1.608529] arm-smmu 51400000.iommu: stage 2 translation
[ 1.613924] arm-smmu 51400000.iommu: nested translation
[ 1.619240] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 1.626376] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 1.632999] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 1.639529] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 1.646059] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.680349] imx6q-pcie 5f000000.pcie: Link up
[ 1.684716] imx6q-pcie 5f000000.pcie: Link up
[ 1.689072] imx6q-pcie 5f000000.pcie: Link up, Gen1
[ 1.696683] imx6q-pcie 5f000000.pcie: PCI host bridge to bus 0000:00
[ 1.703045] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.708534] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.714717] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fefffff]
[ 1.721610] pci 0000:00:00.0: [1957:0000] type 01 class 0x060400
[ 1.727627] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[ 1.733904] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x00ffffff pref]
[ 1.740636] pci 0000:00:00.0: supports D1 D2
[ 1.740941] dpu-core 56180000.dpu: driver probed
[ 1.744908] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 1.750086] pci 0000:01:00.0: [14e4:43ef] type 00 class 0x028000
[ 1.766289] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 1.774936] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.778226] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x003fffff 64bit]
[ 1.781555] [drm] No driver support for vblank timestamp query.
[ 1.788619] pci 0000:01:00.0: supports D1 D2
[ 1.794355] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 1.798524] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.802524] pci 0000:00:00.0: BAR 0: assigned [mem 0x60000000-0x60ffffff]
[ 1.806684] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 1.813244] pci 0000:00:00.0: BAR 6: assigned [mem 0x61000000-0x61ffffff pref]
[ 1.813248] pci 0000:00:00.0: BAR 14: assigned [mem 0x62000000-0x625fffff]
[ 1.820379] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 1.828125] pci 0000:01:00.0: BAR 2: assigned [mem 0x62000000-0x623fffff 64bit]
[ 1.828151] pci 0000:01:00.0: BAR 0: assigned [mem 0x62400000-0x62407fff 64bit]
[ 1.833063] brd: module loaded
[ 1.835624] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 1.842260] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.849740] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 1.856792] pci 0000:00:00.0: bridge window [mem 0x62000000-0x625fffff]
[ 1.893900] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 1.901299] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 1.911026] imx-drm display-subsystem: master bind failed: -517
[ 1.917003] dpu-core 57180000.dpu: driver probed
[ 1.924721] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.927139] loop: module loaded
[ 1.931350] [drm] No driver support for vblank timestamp query.
[ 1.931432] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 1.940049] fsl_lpspi 5a020000.spi: dma setup error -19, use pio
[ 1.940493] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 1.950645] tun: Universal TUN/TAP device driver, 1.6
[ 1.954685] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 1.963619] PPP generic driver version 2.4.2
[ 1.967822] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 1.975840] PPP BSD Compression module registered
[ 1.979323] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 1.986441] PPP Deflate Compression module registered
[ 1.991257] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 1.998418] PPP MPPE Compression module registered
[ 2.003502] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.010832] NET: Registered protocol family 24
[ 2.015739] imx-drm display-subsystem: master bind failed: -517
[ 2.025006] PPTP driver version 0.8.5
[ 2.030137] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.036604] cdns-usb3 5b110000.usb3: Adding to iommu group 0
[ 2.038975] [drm] No driver support for vblank timestamp query.
[ 2.039042] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.051420] OF: graph: no port node found in /bus@5a000000/i2c@5a800000/tcpc@51
[ 2.057271] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.075333] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[ 2.080903] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.090270] usbcore: registered new interface driver xpad
[ 2.095173] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.106359] imx-sc-rtc scu:rtc: registered as rtc0
[ 2.107822] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.119698] imx-sc-rtc scu:rtc: setting system clock to 1970-01-01T00:00:05 UTC (5)
[ 2.119818] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.127753] i2c /dev entries driver
[ 2.134681] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.143913] __power_supply_register: Expected proper parent device for 'battery'
[ 2.147740] imx-drm display-subsystem: master bind failed: -517
[ 2.158419] __power_supply_register: Expected proper parent device for 'usb'
[ 2.173973] OF: graph: no port node found in /bus@5a000000/i2c@5a800000/tcpc@51
[ 2.185512] trusty-virtio trusty:trusty-virtio: initializing
[ 2.192277] trusty_ipc virtio4: vring0: va(pa) (____ptrval____)(0) qsz 32 notifyid 1
[ 2.192502] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.200132] trusty_ipc virtio4: vring1: va(pa) (____ptrval____)(0) qsz 32 notifyid 2
[ 2.206748] [drm] No driver support for vblank timestamp query.
[ 2.206825] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.214787] trusty-virtio trusty:trusty-virtio: initializing done
[ 2.216144] trusty_ipc virtio4: is online
[ 2.220556] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.231193] device-mapper: uevent: version 1.0.3
[ 2.234859] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.239684] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[ 2.246943] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.255180] sdhci: Secure Digital Host Controller Interface driver
[ 2.258820] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.267114] sdhci: Copyright(c) Pierre Ossman
[ 2.267273] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.274484] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.281417] sdhci-esdhc-imx 5b010000.mmc: Adding to iommu group 1
[ 2.287861] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.292447] mmc0: CQHCI version 5.10
[ 2.298033] imx-drm display-subsystem: master bind failed: -517
[ 2.334047] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.337799] mmc0: SDHCI controller on 5b010000.mmc [5b010000.mmc] using ADMA
[ 2.340684] [drm] No driver support for vblank timestamp query.
[ 2.349384] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.353724] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.360182] usbcore: registered new interface driver usbhid
[ 2.367227] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.372781] usbhid: USB HID core driver
[ 2.380979] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.388230] mxc-isi 58100000.isi: mxc_isi.0 registered successfully
[ 2.392064] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.399709] mxc-isi 58110000.isi: mxc_isi.1 registered successfully
[ 2.405560] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.413191] mxc-isi 58120000.isi: mxc_isi.2 registered successfully
[ 2.419065] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.426485] mxc-isi 58130000.isi: mxc_isi.3 registered successfully
[ 2.432518] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.439861] mxc-isi 58140000.isi: mxc_isi.4 registered successfully
[ 2.448391] imx-drm display-subsystem: master bind failed: -517
[ 2.455500] mxc-isi 58150000.isi: mxc_isi.5 registered successfully
[ 2.461160] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.467786] mxc-isi 58160000.isi: mxc_isi.6 registered successfully
[ 2.473275] [drm] No driver support for vblank timestamp query.
[ 2.480640] mxc-isi 58170000.isi: mxc_isi.7 registered successfully
[ 2.485534] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.499907] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.508114] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.514186] mxc-mipi-csi2 58227000.csi: lanes: 4, name: mxc-mipi-csi2.0
[ 2.515452] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.529298] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.529966] mmc0: Command Queue Engine enabled
[ 2.536629] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.540985] mmc0: new HS400 MMC card at address 0001
[ 2.542162] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[ 2.548298] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.550177] mxc-mipi-csi2 58247000.csi: lanes: 4, name: mxc-mipi-csi2.1
[ 2.553315] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[ 2.557955] imx-drm display-subsystem: master bind failed: -517
[ 2.567247] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[ 2.570221] max9286_mipi 2-006a: max9286_read_reg:read reg error: reg=1e
[ 2.570223] max9286 is not found, chip id reg 0x1e = 0x(ffffffff)
[ 2.574496] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.578383] max9286_mipi 3-006a: max9286_read_reg:read reg error: reg=1e
[ 2.578385] max9286 is not found, chip id reg 0x1e = 0x(ffffffff)
[ 2.579596] ashmem: initialized
[ 2.581386] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (246:0)
[ 2.585644] [drm] No driver support for vblank timestamp query.
[ 2.585696] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.597134] Alternate GPT is invalid, using primary GPT.
[ 2.598340] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.604422] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 2.611132] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.677166] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.684501] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.691832] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.699102] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.708704] imx-drm display-subsystem: master bind failed: -517
[ 2.715349] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.721971] [drm] No driver support for vblank timestamp query.
[ 2.727942] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.736088] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.744291] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.751620] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.758943] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.766279] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.773559] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.783164] imx-drm display-subsystem: master bind failed: -517
[ 2.790055] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.792607] Galcore version 6.4.0.234062
[ 2.796694] [drm] No driver support for vblank timestamp query.
[ 2.806600] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.814739] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.822934] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.830267] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.837604] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.844930] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.852202] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.861800] imx-drm display-subsystem: master bind failed: -517
[ 2.905662] [drm] Initialized vivante 1.0.0 20170808 for 80000000.imx8_gpu1_ss on minor 0
[ 2.914400] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.921024] [drm] No driver support for vblank timestamp query.
[ 2.927035] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.935208] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.943400] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.950701] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.958017] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.965334] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.972651] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 2.982192] imx-drm display-subsystem: master bind failed: -517
[ 2.988658] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.995292] [drm] No driver support for vblank timestamp query.
[ 3.001315] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.009478] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.017663] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.024991] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.032337] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.039696] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.052552] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.062205] imx-drm display-subsystem: master bind failed: -517
[ 3.068682] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.075308] [drm] No driver support for vblank timestamp query.
[ 3.081287] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.089428] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.097593] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.104872] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.112151] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.119432] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.126702] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.136202] imx-drm display-subsystem: master bind failed: -517
[ 3.142291] cs42xx8 1-0048: failed to get device ID, ret = -1
[ 3.148096] cs42xx8: probe of 1-0048 failed with error -1
[ 3.154296] wm8960 5-001a: Failed to issue reset
[ 3.158936] wm8960: probe of 5-001a failed with error -5
[ 3.164802] rpmsg-audio-codec-wm8960 5-001a: Failed to issue reset
[ 3.171007] rpmsg-audio-codec-wm8960: probe of 5-001a failed with error -5
[ 3.201412] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.208066] [drm] No driver support for vblank timestamp query.
[ 3.212951] imx-xtor sound-xtor: tx codec slave 1
[ 3.214080] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.218705] imx-xtor sound-xtor: rx codec slave 1
[ 3.226846] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.232496] imx-xtor sound-xtor: snd-soc-dummy-dai <-> 59040000.sai mapping ok
[ 3.239764] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.246833] imx-xtor sound-xtor: ASoC: no DMI vendor name!
[ 3.252008] netem: version 1.3
[ 3.254224] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.259566] u32 classifier
[ 3.262759] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.269850] input device check on
[ 3.269852] Actions configured
[ 3.271545] xt_time: kernel timezone is -0000
[ 3.272704] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.279883] gre: GRE over IPv4 demultiplexor driver
[ 3.283539] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.286864] IPv4 over IPsec tunneling driver
[ 3.288127] Initializing XFRM netlink socket
[ 3.291440] imx-drm display-subsystem: master bind failed: -517
[ 3.298486] IPsec XFRM device driver
[ 3.304168] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.312953] NET: Registered protocol family 10
[ 3.317054] [drm] No driver support for vblank timestamp query.
[ 3.317107] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.321859] Segment Routing with IPv6
[ 3.327333] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.330890] mip6: Mobile IPv6
[ 3.337593] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.344287] NET: Registered protocol family 17
[ 3.347973] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.355976] NET: Registered protocol family 15
[ 3.359744] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.367746] l2tp_core: L2TP core driver, V2.0
[ 3.370821] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.377946] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.379061] registered taskstats version 1
[ 3.382452] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.389628] Loading compiled-in X.509 certificates
[ 3.389653] Key type ._fscrypt registered
[ 3.394261] imx-drm display-subsystem: master bind failed: -517
[ 3.401308] Key type .fscrypt registered
[ 3.401310] Key type fscrypt-provisioning registered
[ 3.455576] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.462200] [drm] No driver support for vblank timestamp query.
[ 3.468173] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.476308] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.484506] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.491829] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.499149] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.506481] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.513753] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.523322] imx-drm display-subsystem: master bind failed: -517
[ 3.529344] imx_mu 31580000.mu: ignoring dependency for device, assuming no driver
[ 3.537124] imx8qxp-lpcg-clk 5ac90000.clock-controller: ignoring dependency for device, assuming no driver
[ 3.546993] imx8qxp-lpcg-clk 5a4a0000.clock-controller: ignoring dependency for device, assuming no driver
[ 3.556797] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.563422] [drm] No driver support for vblank timestamp query.
[ 3.569402] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.577537] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.585708] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.592995] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.600283] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.607572] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.614849] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.624355] imx-drm display-subsystem: master bind failed: -517
[ 3.634284] isi-m2m 58100000.isi:m2m_device: Register m2m success for ISI.0
[ 3.641684] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.646491] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.648321] [drm] No driver support for vblank timestamp query.
[ 3.657550] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.662043] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.668584] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.676667] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.685222] cfg80211: failed to load regulatory.db
[ 3.693484] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.698525] mx8-img-md: Registered mxc_isi.0.capture as /dev/video1
[ 3.705476] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.712696] mx8-img-md: Registered mxc_isi.1.capture as /dev/video2
[ 3.718981] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.726155] mx8-img-md: Registered mxc_isi.2.capture as /dev/video3
[ 3.732495] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.740635] mx8-img-md: Registered mxc_isi.3.capture as /dev/video4
[ 3.746000] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.753383] mx8-img-md: Registered mxc_isi.4.capture as /dev/video5
[ 3.761793] imx-drm display-subsystem: master bind failed: -517
[ 3.768914] mx8-img-md: Registered mxc_isi.5.capture as /dev/video6
[ 3.774341] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.781132] mx8-img-md: Registered mxc_isi.6.capture as /dev/video7
[ 3.786703] [drm] No driver support for vblank timestamp query.
[ 3.786762] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.794037] mx8-img-md: Registered mxc_isi.7.capture as /dev/video8
[ 3.798963] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.807206] unregister ISI channel: mxc_isi.0
[ 3.813395] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.821521] unregister ISI channel: mxc_isi.1
[ 3.825857] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.833091] unregister ISI channel: mxc_isi.2
[ 3.837452] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.844619] unregister ISI channel: mxc_isi.3
[ 3.849044] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.856210] unregister ISI channel: mxc_isi.4
[ 3.860588] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.867809] unregister ISI channel: mxc_isi.5
[ 3.872303] imx-drm display-subsystem: master bind failed: -517
[ 3.881575] unregister ISI channel: mxc_isi.6
[ 3.896228] unregister ISI channel: mxc_isi.7
[ 3.900918] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.907044] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 3.907553] [drm] No driver support for vblank timestamp query.
[ 3.914902] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 3.920488] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.927299] ALSA device list:
[ 3.935362] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.938320] #0: xtor-audio
[ 3.946462] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.956580] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.964040] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.971333] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.978616] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 3.988133] imx-drm display-subsystem: master bind failed: -517
[ 3.994192] device-mapper: init: attempting early device configuration.
[ 4.003110] device-mapper: init: adding target '0 3095928 verity 1 PARTUUID=77007a91-b44b-4afd-9642-8ddbd67d6e01 PARTUUID=77007a91-b44b-4afd-9642-8ddbd67d6e01 4096 4096 386991 386991 sha1 9e2d846c209b792ec1194e97f2d4c0d9eeef12d9 b5a4350c7e245881753febee8770b3a3772b8787 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=77007a91-b44b-4afd-9642-8ddbd67d6e01 fec_roots 2 fec_blocks 390040 fec_start 390040'
[ 4.040780] device-mapper: verity: sha1 using implementation "sha1-ce"
[ 4.048037] device-mapper: init: dm-0 is ready
[ 4.059810] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 4.066918] VFS: Mounted root (ext4 filesystem) readonly on device 254:0.
[ 4.074030] devtmpfs: mounted
[ 4.078141] Freeing unused kernel memory: 2240K
[ 4.090227] Run /init as init process
[ 4.109414] random: init: uninitialized urandom read (40 bytes read)
[ 4.216982] random: init: uninitialized urandom read (40 bytes read)
[ 4.246036] init: init first stage started!
[ 4.251961] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 4.295904] init: [libfs_avb]Returning avb_handle with status: Success
[ 4.302998] init: [libfs_avb]Built verity table: '1 /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/product_a /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/product_a 4096 4096 451493 451493 sha1 561dddcdebeb7295a4f7bbc70b2937d77a2d3928 407f210331d35ccefab5944c7d6d27bef6a95ecf 10 use_fec_from_device /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/product_a fec_roots 2 fec_blocks 455050 fec_start 455050 restart_on_corruption ignore_zero_blocks'
[ 4.347166] device-mapper: verity: sha1 using implementation "sha1-ce"
[ 4.358537] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-1
[ 4.368414] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 4.377787] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/product,type=ext4)=0: Success
[ 4.387119] init: [libfs_avb]Built verity table: '1 /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/vendor_a /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/vendor_a 4096 4096 128983 128983 sha1 3da25b535b0ba1eed35a874454ce1375990934b7 fe10509b2b33797dedac8b16cb143c16e1cca713 10 use_fec_from_device /dev/block/platform/bus@5b000000/5b010000.mmc/by-name/vendor_a fec_roots 2 fec_blocks 130000 fec_start 130000 restart_on_corruption ignore_zero_blocks'
[ 4.429551] device-mapper: verity: sha1 using implementation "sha1-ce"
[ 4.440149] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-2
[ 4.449989] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 4.459361] init: [libfs_mgr]__mount(source=/dev/block/dm-2,target=/vendor,type=ext4)=0: Success
[ 4.470089] init: DM_DEV_STATUS failed for scratch: No such device or address
[ 4.504971] printk: init: 1 output lines suppressed due to ratelimiting
[ 4.512046] random: init: uninitialized urandom read (40 bytes read)
[ 4.565288] init: Loading SELinux policy
[ 4.600093] SELinux: Permission nlmsg_readpriv in class netlink_route_socket not defined in policy.
[ 4.609670] SELinux: the above unknown classes and permissions will be denied
[ 4.616876] SELinux: policy capability network_peer_controls=1
[ 4.622804] SELinux: policy capability open_perms=1
[ 4.627772] SELinux: policy capability extended_socket_class=1
[ 4.633696] SELinux: policy capability always_check_network=0
[ 4.639534] SELinux: policy capability cgroup_seclabel=0
[ 4.644940] SELinux: policy capability nnp_nosuid_transition=1
[ 4.681287] audit: type=1403 audit(8.064:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[ 4.681575] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 4.681575]
[ 4.700445] audit: type=1404 audit(8.084:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1
[ 4.728010] selinux: SELinux: Loaded file_contexts
[ 4.728010]
[ 4.784440] init: init second stage started!
[ 4.823270] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 4.837575] selinux: SELinux: Loaded file_contexts
[ 4.837575]
[ 4.843899] init: Running restorecon...
[ 4.871402] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'quicken'
[ 4.882812] init: Couldn't load property file '/product_services/build.prop': open() failed: No such file or directory: No such file or directory
[ 4.895908] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
[ 4.911017] init: Setting product property ro.product.brand to 'Android' (from ro.product.product.brand)
[ 4.920558] init: Setting product property ro.product.device to 'mek_8q' (from ro.product.product.device)
[ 4.930199] init: Setting product property ro.product.manufacturer to 'freescale' (from ro.product.product.manufacturer)
[ 5.046449] ueventd: ueventd started!
[ 5.052435] selinux: SELinux: Loaded file_contexts
[ 5.052435]
[ 5.058919] ueventd: Parsing file /ueventd.rc...
[ 5.064254] ueventd: Parsing file /vendor/ueventd.rc...
[ 5.070235] ueventd: Parsing file /odm/ueventd.rc...
[ 5.075243] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[ 5.085015] ueventd: Parsing file /ueventd.freescale.rc...
[ 5.090530] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[ 5.110396] apexd: Bootstrap subcommand detected
[ 5.125325] apexd: Scanning /system/apex for embedded keys
[ 5.131886] apexd: Scanning /product/apex for embedded keys
[ 5.137645] apexd: ... does not exist. Skipping
[ 5.142323] apexd: Scanning /system/apex looking for APEX packages.
[ 5.148791] apexd: Found /system/apex/com.android.runtime.debug
[ 5.155211] apexd: Successfully bind-mounted flattened package /system/apex/com.android.runtime.debug on /apex/com.android.runtime@1
[ 5.167396] apexd: Found /system/apex/com.android.tzdata
[ 5.173088] apexd: Successfully bind-mounted flattened package /system/apex/com.android.tzdata on /apex/com.android.tzdata@290000000
[ 5.185219] apexd: Found /system/apex/com.android.resolv
[ 5.194394] printk: apexd: 9 output lines suppressed due to ratelimiting
[ 5.303127] ueventd: Coldboot took 0.201 seconds
[ 5.337554] Registered swp emulation handler
[ 5.367897] watchdogd: watchdogd started (interval 10, margin 20)!
[ 5.384029] logd.auditd: start
[ 5.387150] logd.klogd: 5252961000
[ 5.507416] EXT4-fs (mmcblk0p16): Ignoring removed nomblk_io_submit option
[ 5.632826] EXT4-fs (mmcblk0p16): 1 orphan inode deleted
[ 5.638155] EXT4-fs (mmcblk0p16): recovery complete
[ 5.646981] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 6.428282] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
[ 6.428282]
[ 6.434351] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 6.434351]
[ 6.441691] e2fsck: Pass 2: Checking directory structure
[ 6.441691]
[ 6.448490] e2fsck: Pass 3: Checking directory connectivity
[ 6.448490]
[ 6.455557] e2fsck: Pass 4: Checking reference counts
[ 6.455557]
[ 6.462104] e2fsck: Pass 5: Checking group summary information
[ 6.462104]
[ 6.469427] e2fsck: /dev/block/by-name/userdata: 3084/350192 files (2.0% non-contiguous), 46487/1398784 blocks
[ 6.469427]
[ 6.484912] EXT4-fs (mmcblk0p16): Ignoring removed nomblk_io_submit option
[ 6.495547] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 7.874216] random: crng init done
[ 7.877633] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.898200] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
[ 7.971934] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
[ 8.012439] apexd: Marking APEXd as starting
[ 8.018378] apexd: Scanning /system/apex for embedded keys
[ 8.025036] apexd: Scanning /product/apex for embedded keys
[ 8.030748] apexd: ... does not exist. Skipping
[ 8.035329] apexd: Populating APEX database from mounts...
[ 8.041042] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[ 8.051846] apexd: Found "/apex/com.android.runtime@1"
[ 8.057075] apexd: Found "/apex/com.android.tzdata@290000000"
[ 8.062909] apexd: 2 packages restored.
[ 8.066893] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
[ 8.356481] logd.daemon: reinit
[ 8.399767] update_verifier: Started with arg 1: nonencrypted
[ 8.408527] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 8.415033] update_verifier: Leaving update_verifier.
[ 8.427865] type=1400 audit(11.812:4): avc: denied { setattr } for comm="init" name="wifi" dev="mmcblk0p16" ino=276919 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=0
[ 8.446815] type=1400 audit(11.812:4): avc: denied { setattr } for comm="init" name="wifi" dev="mmcblk0p16" ino=276919 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=0
[ 8.465662] type=1400 audit(11.812:5): avc: denied { search } for comm="init" name="wifi" dev="mmcblk0p16" ino=276919 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=0
[ 8.484390] type=1400 audit(11.812:5): avc: denied { search } for comm="init" name="wifi" dev="mmcblk0p16" ino=276919 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=0
[ 8.484935] using random self ethernet address
[ 8.502929] type=1400 audit(11.812:6): avc: denied { setattr } for comm="init" name="dhcp" dev="mmcblk0p16" ino=276923 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=0
[ 8.507326] using random host ethernet address
[ 8.509857] file system registered
[ 8.686393] type=1400 audit(11.812:7): avc: denied { setattr } for comm="init" name="dhcp" dev="mmcblk0p16" ino=276923 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=0
[ 8.696217] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
mek_8q:/ $ [ 8.781896] pb_decode failed
[ 8.797056] this type is not correct: 0:0:0!
[ 8.798925] type=1400 audit(12.068:8): avc: denied { read } for comm="healthd" name="type" dev="sysfs" ino=30655 scontext=u:r:healthd:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 8.857726] [VPU Encoder] enable mu for core[0]
[ 8.867234] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 8.873308] [VPU Encoder] vpu encoder core[0] firmware version is 1.2.7
[ 9.328496] read descriptors
[ 9.331415] read strings
[ 10.031149] init: Received control message 'start' for 'bootanim' from pid: 355 (/system/bin/surfaceflinger)
[ 10.042897] init: starting service 'bootanim'...
[ 12.849719] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 12.853139] init: Received control message 'start' for 'idmap2d' from pid: 582 (system_server)
[ 12.859175] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 12.890310] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.043570] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:807)
[ 13.094864] init: Received control message 'interface_start' for '[email protected]::IOemLock/default' from pid: 336 (/system/bin/hwservicemanager)
[ 13.109282] init: Could not find '[email protected]::IOemLock/default' for ctl.interface_start
[ 13.225304] type=1400 audit(13.016:29): avc: denied { read } for comm="[email protected]" name="u:object_r:exported_ffs_prop:s0" dev="tmpfs" ino=3140 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:exported_ffs_prop:s0 tclass=file permissive=0 duplicate messages suppressed
[ 13.249770] type=1400 audit(1669791119.272:30): avc: denied { read } for comm="system_server" name="state" dev="sysfs" ino=30733 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 13.254676] read descriptors
[ 13.271721] read strings
[ 13.274410] read descriptors
[ 13.277316] read strings
[ 13.297502] acc_open
[ 13.299728] acc_release
[ 13.816401] selinux: SELinux: Skipping restorecon on directory(/data/system_ce/0)
[ 13.816401]
[ 13.827582] init: Async property child exited with status 0
[ 13.840329] selinux: SELinux: Skipping restorecon on directory(/data/vendor_ce/0)
[ 13.840329]
[ 13.851292] init: Async property child exited with status 0
[ 14.212204] type=1400 audit(1669791119.272:30): avc: denied { read } for comm="system_server" name="state" dev="sysfs" ino=30733 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 14.237427] type=1400 audit(1669791120.260:31): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.deskclock
[ 14.379745] this type is not correct: 289409539:0:82!
[ 14.385259] receive power state report with value 0
[ 14.417059] receive power state report with value 0
[ 14.903193] this type is not correct: 289409539:0:82!
[ 15.353229] type=1400 audit(1669791120.260:31): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.deskclock
[ 15.377208] type=1400 audit(1669791121.400:32): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c522,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file
[ 15.638659] this type is not correct: 289409539:0:82!
[ 17.222857] this type is not correct: 289409539:0:82!
[ 20.746242] type=1400 audit(1669791121.400:32): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c522,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file
[ 20.768568] type=1400 audit(1669791126.792:33): avc: denied { search } for comm="RenderThread" name="com.android.car.mapsplaceholder" dev="mmcblk0p16" ino=179245 scontext=u:r:platform_app:s0:c522,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=0
[ 20.848789] type=1400 audit(1669791126.796:50): avc: denied { search } for comm="RenderThread" name="com.android.car.mapsplaceholder" dev="mmcblk0p16" ino=179245 scontext=u:r:platform_app:s0:c522,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=0 duplicate messages suppressed
[ 20.875526] type=1400 audit(1669791126.896:51): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c522,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file
[ 23.580670] apexd: Can't open /product/apex for reading : No such file or directory
[ 23.868321] init: Received control message 'start' for 'gsid' from pid: 582 (system_server)
[ 23.877005] init: starting service 'gsid'...
[ 23.949692] init: Received control message 'stop' for 'gsid' from pid: 582 (system_server)
[ 23.958006] init: Sending signal 9 to service 'gsid' (pid 1577) process group...
[ 23.970674] libprocessgroup: Successfully killed process cgroup uid 0 pid 1577 in 5ms
[ 23.979027] init: Service 'gsid' (pid 1577) received signal 9
[ 24.113485] init: Received control message 'stop' for 'idmap2d' from pid: 582 (system_server)
[ 24.122158] init: Sending signal 9 to service 'idmap2d' (pid 450) process group...
[ 24.135413] libprocessgroup: Successfully killed process cgroup uid 1000 pid 450 in 5ms
[ 24.144693] init: Service 'idmap2d' (pid 450) received signal 9
[ 26.439845] binder: undelivered transaction 25185, process died.
[ 26.445915] binder: undelivered transaction 25189, process died.
[ 26.451952] binder: undelivered transaction 25192, process died.
[ 26.454331] sdcardfs version 2.0
[ 26.458061] binder: undelivered transaction 25157, process died.
[ 26.461344] sdcardfs: dev_name -> /data/media
[ 26.467282] binder: undelivered transaction 25186, process died.
[ 26.471585] sdcardfs: gid=1015,mask=6
[ 26.471627] sdcardfs: mounted on top of /data/media type ext4
[ 26.485894] binder_alloc: 1916: binder_alloc_buf, no vma
[ 26.487253] binder: undelivered transaction 25190, process died.
[ 26.487323] binder: undelivered transaction 25183, process died.
[ 26.510912] binder: 582:601 transaction failed 29189/-3, size 240-0 line 3312
[ 26.519425] init (pid 1) is setting deprecated v1 encryption policy; recommend upgrading to v2.
[ 26.747582] bt power gpio is:374
[ 26.754680] rfkill: BT RF going to : on
[ 26.759387] mxc_bt_rfkill_reset
[ 26.762912] mxc_bt_rfkill driver success loaded
[ 26.769321] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 26.778141] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 26.785650] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 26.792590] [drm] No driver support for vblank timestamp query.
[ 26.799033] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 26.807628] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 26.816805] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 26.824393] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 26.831902] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 26.839339] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 26.846767] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 26.856459] imx-drm display-subsystem: master bind failed: -517
[ 26.897414] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 26.910596] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 26.917806] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 26.924498] [drm] No driver support for vblank timestamp query.
[ 26.930567] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 26.938853] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 26.951656] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 26.959401] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 26.966900] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 26.974520] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 26.981984] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 26.982607] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 26.991811] imx-drm display-subsystem: master bind failed: -517
[ 27.006509] brcmfmac 0000:01:00.0: enabling device (0000 -> 0002)
[ 27.031854] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 27.039704] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 27.046964] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 27.055699] [drm] No driver support for vblank timestamp query.
[ 27.062549] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 27.075537] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 27.085011] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 27.093171] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 27.100679] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 27.109237] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 27.116670] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 27.119126] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-pcie for chip BCM4359/5
[ 27.126527] imx-drm display-subsystem: master bind failed: -517
[ 27.136966] imx_usb 5b0d0000.usb: 5b0d0000.usb supply vbus not found, using dummy regulator
[ 27.141780] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 27.154963] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 27.156593] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 27.161256] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 27.168150] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 27.182996] rfkill: BT RF going to : off
[ 27.187421] [drm] No driver support for vblank timestamp query.
[ 27.190250] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 27.193578] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 27.199262] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 27.207073] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 27.215516] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 27.223619] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 27.230800] usb usb1: Product: EHCI Host Controller
[ 27.238124] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 27.243251] usb usb1: Manufacturer: Linux 5.4.24-dirty ehci_hcd
[ 27.250304] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 27.256608] usb usb1: SerialNumber: ci_hdrc.0
[ 27.263642] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 27.274317] hub 1-0:1.0: USB hub found
[ 27.275643] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 27.281077] hub 1-0:1.0: 1 port detected
[ 27.288792] imx-drm display-subsystem: master bind failed: -517
[ 27.300021] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 27.307743] imx-wm8960 sound-wm8960: failed to find codec platform device
[ 27.315807] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 27.322494] [drm] No driver support for vblank timestamp query.
[ 27.328628] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 27.337036] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 27.345716] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 27.353859] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 27.357875] usbcore: registered new interface driver usb-storage
[ 27.362978] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 27.375195] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 27.382610] imx-drm display-subsystem: failed to bind bus@56240000:ldb@562410e0 (ops imx_ldb_ops): -517
[ 27.392574] imx-drm display-subsystem: master bind failed: -517
[ 27.791991] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-pcie for chip BCM4359/5
[ 27.806289] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4359/5 wl0: Feb 20 2019 18:05:52 version 9.40.109 (r710128 CY) FWID 01-848095d2
[ 33.592179] type=1400 audit(1669791126.896:51): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=3167 scontext=u:r:untrusted_app_25:s0:c522,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file
[ 33.612791] type=1400 audit(1669791139.640:52): avc: denied { read } for comm="pool-1-thread-1" name="life_time" dev="sysfs" ino=31427 scontext=u:r:carservice_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 33.632636] type=1400 audit(1669791139.640:52): avc: denied { read } for comm="pool-1-thread-1" name="life_time" dev="sysfs" ino=31427 scontext=u:r:carservice_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 33.652173] type=1400 audit(1669791139.640:53): avc: denied { read } for comm="pool-1-thread-1" name="pre_eol_info" dev="sysfs" ino=31426 scontext=u:r:carservice_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 33.890250] vref_1v8: disabling
[ 33.893406] SD1_SPWR: disabling
Efecan
5,678 次查看
cbl
Contributor V
Hello @Bio_TICFSL,
I correctly configured my pwm settings in defconfig and devicetree files and was able to drive my LVDS panel.
Efecan
5,681 次查看
Bio_TICFSL
It looks like your image is not building correctly, try to boot with uboot first, you must be enable both LVDS in there, then you boot the complete image.
5,679 次查看
cbl
Contributor V
Hello @Bio_TICFSL,
Efecan
