Hi All,
I'm using Android 9 in imx6 board.
I'm using USB H1 and defined in fstab.freescale.
/devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1* auto auto defaults voldmanaged=usb:auto
After boot If I insert pendrive its detected under /dev/block/sda1
But it not showing inside /dev/block/vold/ .
So its not auto mounting also.
Can you please help to fix it.
Aravinth
Could you please share which i.MX6 are you using?
is it a custom board or an NXP board?
If possible, could you share the full logs?
Also, please remember that if you're using i.MX6 SABRE Board the only USB supported should be the OTG one, and it is already defined at fstab.freescale:
/devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0* auto auto defaults voldmanaged=usb:auto
Aldo.
