An unknown SECO event occurred using i.MX8
1,088件の閲覧回数
minsiklee
Hi all,
When I do sc_seco_sab_msg(), the following seco event occurs.
Life cycle : 0x 80, OEM closed
SECO Event[0] = 0x C1F729
1. What does "addr: address of message block" mean among the two sc_seco_sab_msg() api parameters? (it mean the flash ram address?)
2. What does seco event 0xC1F729 mean?
If anyone knows what the event means and how it needs to be handled, that would be of great help.
Thank you
best regard.
タグ(3)
1,004件の閲覧回数
tthalath
0xC1F729
29 - The request failed       -   AHAB_FAILURE_IND
F7 - Bad container             - AHAB_BAD_CONTAINER_IND
C1 - Operation done in (SNVS) non-secure state   - AHAB_NON_SECURE_STATE_IND
7 返答(返信)
1,005件の閲覧回数
tthalath
0xC1F729
993件の閲覧回数
minsiklee
HI @tthalath
Thank you for your reply.
Can you tell us which document you are referring to?
Best,
Duncan
1,047件の閲覧回数
Dhruvit
Hi @minsiklee,
I hope you are doing well.
Please mention the scfw porting kit version and the Linux BSP version that you are using.
One can refer to 18.20 SECO: Security Controller Driver (Enumration ) in System Controller Firmware Porting Guide.
1. What does "addr: address of message block" mean among the two sc_seco_sab_msg() api parameters? (Does it mean the flash ram address?)
[Ans]: address of the message block refers to where the signed message block can be found.
Please make sure that you are using the latest scfw for Linux BSP used as shown in the below link.
Thanks & Regards,
Dhruvit Vasavada
1,041件の閲覧回数
minsiklee
Hi @Dhruvit.
Thank you for your kind reply.
Linux BSP version and scfw porting kit version are used to support i.MX 8DXL.
(maybe, using Linux 5.4.70_2.3.0​, SCFW Porting Kit​ 1.10.0 or later version)
I would appreciate it if you could answer the question 2 I asked.
(2. What does seco event 0xC1F729 mean?)
Duncan.
1,034件の閲覧回数
Dhruvit
Hi @minsiklee,
I have sent you an email regarding this error.
Thanks & Regards,
Dhruvit Vasavada
1,010件の閲覧回数
minsiklee
Hi, @Dhruvit
Could you let us have your feedback for the questions?
Haven't received an email yet.
duncan
1,064件の閲覧回数
minsiklee
For additional information, the SECO API return value is 3, which is defined as follows in the System Controller Firmware Porting Guide document.
The value of 0xC1F729 seems to be one of the following, but I don't know which one.
– AHAB_UNKNOWN_BID_IND
– AHAB_UNALIGNED_PAYLOAD_IND
– AHAB_WRONG_SIZE_IND
– AHAB_OTP_INVALID_IDX_IND
– AHAB_ADM_WRONG_LC_IND
– AHAB_OTP_DED_IND
– AHAB_BAD_PAYLOAD_IND
– AHAB_WRONG_ADDRESS_IND
– AHAB_DMA_FAILURE_IND
– AHAB_BAD_UID_IND
– AHAB_INCONSISTENT_PAR_IND
– AHAB_BAD_MONOTONIC_COUNTER_IND
– AHAB_BAD_SRK_SET_IND
– AHAB_BAD_ID_IND
